PDA
View Full Version : Ford 83-94 6.9 and 7.3L General
Pages : 1 2 3 4 [5] 6 7 8
  1. 89 250
  2. 1993 IDI stock (Ambulance pkg) fuel flow issue?!?! HELP!!!!
  3. speedometer ?
  4. anyone looking to buy 7.3 idi
  5. To Turbo or Not to Turbo?
  6. Blue smoke issue! Please help!
  7. turbo down pipe
  8. digital odometer and speedometer stopped working
  9. Block heater
  10. im stuck
  11. 94 IDI Turbo
  12. Another Hard Start 7.3 IDI
  13. random qustion
  14. Which Antifreeze
  15. 4x4 indicator?
  16. cold cranks then dies
  17. brake issue
  18. injector
  19. seem to lack power on hills
  20. 7.3 glow plug controler issue
  21. clutch linkage
  22. Injection Pump
  23. gasket ?s
  24. Injector ?
  25. wastegate adjustment
  26. tach sensor= tranny problems?
  27. Starter solenoid
  28. 92 7.3 want to upgrade exhaust and intake
  29. Gauges
  30. 7.3 idi issues need help
  31. question on E40D
  32. heater valve?
  33. Cold starting
  34. vacuum line?
  35. Glow plug info for an 86 6.9...and ign switch replacement
  36. Howling noise like the wind on acceleration
  37. 1990 f350 fuel tank selector
  38. ATS Factory turbo
  39. 1983 i6 4bt swap
  40. boost gauge ???s
  41. Fuel tank selector switch does not work
  42. swaping dashes
  43. What to look for when buying a 6.9?
  44. injector problems
  45. Some answers please
  46. Engine knocking noise when first starting
  47. im stumped
  48. 86 ford f250 6.9
  49. Removing 89 7.3ltr IDI Injector Pump
  50. 1994 F 350 IDI Turbo Diesel
  51. 1989 f250 diesel cummins swap
  52. 86 Ford 250 6.9 7 & 8 cylinders
  53. Why did they split the 94 yr its so confusing !
  54. Air in the fuel??
  55. 1989 351 to cummins swap questions
  56. k and N Cold air induction
  57. Early 94 7.3 Turbo Diesel
  58. lift kit??
  59. high output 6.9 IDI
  60. performance gains from turning up IP
  61. Having issues when towing heavy load ???
  62. overdrive button
  63. Pick-Up Tube and Screen
  64. injector caps/o rings and return lines
  65. Windshield Wipers???
  66. Body change ???
  67. Rear drum removal. Dually. Sterling 10.25?
  68. winter oil
  69. alternator
  70. Tuner/Chip
  71. 6.9 Been sitting for ten years. Rough Idle. White/Blue smoke
  72. 94 7.3 idi turbo, smoking acting retarded
  73. Fuel not getting to injectors but is hitting the filter fine!!!
  74. N/A IDI vs. TIDI
  75. Transmission issuses please help
  76. 97 7.3 power loss
  77. need help with 6.9 not getting fuel
  78. 7.3L IDI cranks but no start
  79. New to the 6.9 world
  80. Over Drive Light on 7.3 Automatic
  81. IP
  82. New GlowPlugs & Relay
  83. air fuel ratio gauge
  84. Glow Plug Problem
  85. 6.9 anti freeze leak
  86. worth it?
  87. 6.9 performance
  88. Stalls
  89. 1989 idi 7.3 or 6.9
  90. pyro meter
  91. speedometer cable location 6.9 ford
  92. 1992 F250 Orfice tube removal?
  93. 94 f250 speedometer doesnt work
  94. 7.3 on the way out
  95. tach issues on 92 f250
  96. ip or not
  97. 1994 idi turbo spool
  98. EGR delete on '88 7.3?
  99. 89 7.3
  100. do our idis have turbo silencers?
  101. axel year
  102. church bus
  103. transmission prt
  104. '87 7.3 idi with '88 drivetrain which trans lube?
  105. 1989 antifreeze leaking in engine
  106. Lift
  107. 6.9L IDI smoke questions
  108. dumb question
  109. 88 7.3 pooring smoke
  110. hello
  111. 94 7.3 won't start either
  112. 6.9 idle
  113. erratic low oil pressure
  114. parting out an 89 f250 6.9 auto
  115. Which Starter for my 7.3 IDI
  116. Engine prices
  117. clutch
  118. craig.sun
  119. help f350
  120. 91 IDI trans problem
  121. turbos
  122. Vacuum Pump
  123. Zero fuel pressure
  124. transmission
  125. Fuel Injection Pump wires
  126. anyone ever done a fummins kit?
  127. Can I ?
  128. 7.3L non-turbo heads
  129. New to forum..greetings...my problem..
  130. electrical problem... Help me please!!!
  131. Thinking I need a new fuel pump... where to get it?
  132. 1994 ford f250 7.3 idi turbo diesel problem
  133. pyro gauge install
  134. starting problem on a 7.3
  135. IDI Problems
  136. help with my 1985 f250 6.9 project
  137. New to me Ford F-250
  138. New ip or ip timing?
  139. 7.3 idi won't start
  140. Voltmeter shows discharge
  141. Need Some Help GUYS
  142. need some help on my 6.9 idi
  143. Fuel Tank Capacity
  144. Need some wiring help please. 92 vs 93 idi transmission harness ?'s
  145. AFM switch
  146. 6.9 Injector Pump Swap
  147. 92 F350 not charging.
  148. 1989 7.3 4x4 5 speed 1500$
  149. tranny pump
  150. 90 idi and trans
  151. cruise control
  152. What accessories are still available for 1991 F250?
  153. what is feesable with a 6.9L
  154. Front Oil Seal
  155. Tach sensor?
  156. Father's Day
  157. Help 93 7.3
  158. Power Steering Pump
  159. upper radiator hose
  160. clutch help
  161. looking for a remanufactured engine
  162. injector return lines
  163. can I get constant RPM from the DB2 ip?
  164. 7.3 idi fuel injection pump
  165. Thank You and another ?
  166. Brake fittings and lines
  167. 1991 Ford F250 4X4 Diesel Pick Up a Good Buy?
  168. idi stickers
  169. 93 wont start wen hot
  170. dana 50 or dana 60
  171. Transmission E4OD
  172. 91 f350 7.3 wont start
  173. Serpentine Belt
  174. power..PoWeR... POWER
  175. ats non wastegated
  176. '90 7.3L dies
  177. 1994 F-250
  178. Exhaust brakes
  179. electrics in the dash
  180. Idle Solenoid Problem
  181. new to the diesel world and need help
  182. injecter problems an head gaskets maybe
  183. miss maybe ??
  184. questionable power
  185. help
  186. turning up injection pump
  187. WTF.. My IDI is doing worse stuff
  188. 1993 f250 no power towing..
  189. smoking like a train while towing/no power
  190. guage cluster problems
  191. smoke and tranny
  192. dana 61 noises
  193. turbo question
  194. glow plug relay
  195. 91' ford f250 7.3 no tach.
  196. performance parts
  197. gauge pillar
  198. 1994 ford 7.3l turbo diesel
  199. 1994 ford 7.3l turbo diesel (help please)
  200. 94 7.3 turbo deisel
  201. egt question????
  202. 1983 f250
  203. Fuel Pump Adjustment
  204. 85 f250 6.9
  205. swap or rebuild?
  206. Front left clicking
  207. turning up ip
  208. Exhaust Clamp
  209. whats a good fuel tratment
  210. 1986 6.9 loss of power
  211. Lift pump on a 6.9?
  212. replaced gp's and wired the gpr wrong
  213. 93 7.3 non-turbo
  214. what is a flat
  215. New to the 6.9l and diesels
  216. turning up pump
  217. 92 f250 7.3 idi NA, startin problem
  218. c6 to 5 speed will it make a problem
  219. what are common problems for a 88 ford 7.3
  220. mileage
  221. HELP...START AND IDLE FINE, FUEL FILTER LIGHT COMES ON DURING ACCELERATION...DIES
  222. Cab Change
  223. 89 building up too much pressure
  224. fuel issue?
  225. 89 7.3l idi wiring issues
  226. timing....
  227. IDI De-turboed
  228. cummins swap
  229. 85 ford axle code
  230. lift vs. driveshafts
  231. About to open the IP on my 7.3 IDI
  232. dana 60?
  233. Wheel questions
  234. Need body lift for 1993 f250 ext cab 7.3 idi 2wd
  235. burnt?
  236. New Radiator
  237. twin turbos
  238. head light relay
  239. what the tops speed of a non turbo 1983 idi
  240. white smoke
  241. Injectors?
  242. over heating my 7.3
  243. 94 f350
  244. Turning up injection pump on 93 7.3L
  245. water temp
  246. tire options
  247. Glow Plugs
  248. Auto trans coming out of gear ?
  249. Turbo flange and down pipe
  250. engine caught fire
