PDA
View Full Version : Ford 83-94 6.9 and 7.3L General
Pages : 1 2 [3] 4 5 6 7 8
  1. Just bought a 7.3L IDI, What now?
  2. F250 7.3 idi
  3. 94 IDI Motor
  4. 93 Ford E350 E4OD Speed Sensor Location
  5. 94 7.3 TURBO DIESEL AUTOMATIC
  6. 1987 6.9 turbo oil return still leaking
  7. turning into a dually
  8. E4OD Rpm's Too High In O/D
  9. RADIATOR PRESSURING UP!!!!
  10. my take on headlight relays.....
  11. 7.3 idi engine swap to 7.3 idi turbo
  12. constant smoke
  13. 93 ford 7.3 turbo international wont start help!!!
  14. Temp sensor and Glow Plug controller question
  15. Looking for a 7.3 idi and/or a e4od for sale?
  16. 6.9/7.3 IDI Turbo system
  17. Cummins swap into 74 Ford 2wd
  18. 1986 6.9L issues
  19. PCM
  20. my homeade fuel concoction
  21. 92 7.3 idi acceleration knock and a studder in higer rpm
  22. Vacuum Switch?
  23. IDI Temperature Guage
  24. Idi miss and white smoke
  25. trany swaps
  26. 94 F-250 7.3 IDI Crank no start
  27. Olive drab trucks?
  28. 6.9 Fuel Tank Building Extreme Pressure
  29. Suspension lift
  30. 7.3 idi clutch replacement
  31. Fluid leak help
  32. Need advice on 93 f-250
  33. :s:please help
  34. am i screwed
  35. Guages
  36. help me please
  37. possible flywheel problems/ thumping by tranny
  38. Glow Plug Controller problem
  39. 6.9 idi wont start
  40. Factory IDI turbo size?
  41. Holset turbo on a 7.3 IDI
  42. What kind of muffler should I get?
  43. e4od tranny needed
  44. 91 f250 idi needing turbo
  45. 7.3 IDI computer conversion?
  46. 7.3 factory turbo whistle??
  47. 84 f250 6.9 starting problems
  48. Gas truck headers?
  49. Vaccum pump problem ?
  50. 1991 Ford F250 2 dr 4X4 7.3 Diesel economy mileage
  51. SOLVED! No wts light, truck wont start cold
  52. help! wont start
  53. 6.9 oil cooler questions
  54. 1994 7.3 idi turbo worth it?
  55. fuse box engine and cab diagram/pic needed... 1992 7.3L
  56. hard starting
  57. Installed DIY cold air intake won't stay running
  58. Buyin an 85 6.9 4x4
  59. Turbo setup
  60. I got two questions
  61. rear anti-lock
  62. Where would I find the inside ground on a 1990 f450 7.3 international?
  63. 1992 7.3 turbo'd IDI Hard HOT START
  64. 7,3 Idi wiring diagrams
  65. lost temper .. now paying price... cut the supply and return line
  66. 6.9 overheating
  67. turned it up..is thatbad?
  68. Where is the glow plug controller located at??
  69. Glow plug controller clicking... and harness
  70. Parking Brake Cable Tensioner
  71. ZF-5 Swap Questions
  72. Power brake booster/vacuum pump?
  73. Single mass fly wheel and clutch
  74. 94 idi wont stay running down the road
  75. centurion?
  76. Overdrive units
  77. Sudden Boosts of power then rough idle and dies...intermittenly
  78. ford regular cab flareside 4x4 5speed 4x4
  79. Selling My Dad F250
  80. how would my 1990 7.3 sound straight piped ?
  81. Axle questions
  82. 6.9 help
  83. wait to start and water in fuel stay on after start
  84. My FIRST ford diesel ! f350
  85. overload towing
  86. ford ranger 2.2 diesel
  87. Please need help quick!
  88. Need some ideas please help!
  89. 7.3 IDI turbo diesel question
  90. Steering shock mount rusted out!
  91. glow plug problem need help
  92. 6.9 idi performence?
  93. Injectors ?
  94. steering issue
  95. white smoke
  96. 7.3idi compression
  97. dually rear-end question
  98. Bell House and Clutch Fork
  99. changing my ijector pump
  100. Oil pressure
  101. help!!
  102. 6.9 and 7.3 injector pump..????? help!!!
  103. injector pump timing
  104. exhaust manifold
  105. power upgrades
  106. 93 7.3 IDI Turbo Recommendations
  107. New job need choices on a truck.
  108. wanna put stacks on my rig...but?
  109. More mods?
  110. 6.9 engine problems
  111. injection pump
  112. Replaced 6.9 injector seals, now won't start
  113. 1984 F250 6.9L NEED HELP
  114. Body lift instead of a leveling kit?
  115. 6.9 non turbo ip questions
  116. 6.9 ignition problems
  117. 6.9 bio diesel conversion
  118. Down pipe !?
  119. 1985 6.9 Injector Leak?
  120. battery light/gauge
  121. Testing help
  122. is fuel return line to filter nessary or can it be removed
  123. Guage pod?
  124. 6.9 diesel in oil
  125. Block heater
  126. 91 idi trouble starting
  127. e40d tranny wire harness
  128. For sale: 1992 F250 IDI 4x4 3/4 ton XLT + extras + additional ATS 093 turbo
  129. Leveling kit on a 1990 f-250?
  130. 6.9l
  131. 95 f350 w/460 swap 7.3
  132. New starter grinding but not starting engine, 6.9L NA
  133. 1991 Ford 7.3 no start
  134. 1994 non-turbo problem solving
  135. Custom Gauge Cluster
  136. Stacks on a flatbed 7.3
  137. head gasket and studs 7.3 idi
  138. 7.3 won't start?
  139. 7.3 idi exhaust
  140. Tranny swap
  141. 1990 ford 7.3 idi f250
  142. 1990 7.3 IDI with ATS aftermarket turbo
  143. 85 6.9L wiring diagram for glow plugs
  144. 85 F-250 Help
  145. really help soon
  146. injector blew up in hole
  147. pyrometer
  148. 7.3 idi turbo
  149. Trans & transfer case problems!
  150. new, to me anyway, 92' f-350 with a unique problem
  151. switched GPs to button but wired like factory
  152. help plz
  153. Front axle size F250 Info needed
  154. GLOW PLUG PROBLEM?
  155. looking to buy a 92' 350
  156. No start...what to do next
  157. Block Heater Question 89F250
  158. lift pump fuel line
  159. Trouble getting bell housing tight to engine
  160. new injector pump
  161. ford-ifs...changing u-joints
  162. 7.3 headgaskets need some advice
  163. transmission help
  164. 1990 F250 7.3 snow plow frame?
  165. 6.9 power build
  166. need some help if ya'll dont mind.
  167. Certain procedure to change glowplugs
  168. help 93 ford diesel smokes
  169. 94' 7.3 non turbo to a powerstroke
  170. seafoam
  171. Battery drain?
  172. 85 F-250 6.9 Help
  173. '94 Factory turbo IDI
  174. 89 F350 No Start Help Please!!!!
  175. Blowin Fuses
  176. tranny help
  177. Attention Powerstroke mechanics HELP NEEDED!
  178. '93 7.3L Kicking my Backside (Starting)
  179. im stumped need help 94 idi non turbo wont start,wont turnover,no clicking,no lights
  180. Im back guys
  181. Fluid levels
  182. Building My IDI
  183. 85 6.9l 4speed clutch slipping
  184. turbo
  185. Mechanic?
  186. 91 f-250 4x4 7.3 diesel, ford f-250 diesel code 10 Cylinder 1 Contribution Or Balance
  187. C7 in the F350
  188. 1989 F250 7.3L IDI talk
  189. 7.3 hard start
  190. 1993 diesel ford f450 sending unit
  191. my 92 f450 7.3l non turbo will not start turns over just dont seem to fire
  192. 7.3 upgrades??
  193. Help
  194. 1990 f250 hard start and tons of white smoke
  195. He351ve turbo on idi
  196. Found my new/first Truck
  197. $300 F350 worth every penny
  198. Looking at an 88 with a bad injector, can I replace it with a junk yard part?
  199. clutch noises please help
  200. Jumping Speedometer
  201. Timing Fuel Pump
  202. Glow plug controller wont turn off.
  203. MLPS Wiring missing
  204. Bad or good glow plug??
  205. what glow plugs should I use?
  206. Alternator
  207. 1992 non turbo 7.3idi
  208. Clutch pedal has no pressure??!!! please help
  209. 1986 e-350 motorhome with a 7.3
  210. Buying an 85-86, what should I know about mpg and ratios
  211. Transmission Slipping
  212. electric fuel pump
  213. Question from a beginer.
  214. 7.3 Glow plugs????
  215. loosing prime
  216. 7.3 Engine Problems
  217. FORD 7.3 IDI, fuel additives
  218. 94 2wd tranny and tach issues
  219. 7.3 international good choice?
  220. Engine Stalls at Idle
  221. my buddies idi, missing???
  222. burned out glow plug
  223. 79 ford f-350 project
  224. 6.9 idi keeps burning out glow plugs
  225. Bath Oil Seal Leak
  226. Not in the engine compartment
  227. Dual wheel tires
  228. my F350
  229. c-6 to a t-19 swap
  230. 6.9 injector pump problems
  231. 1990 f350 fuel guage??????
  232. gp controller test
  233. transmission swap ? for Overdrive
  234. i need opinions! new 600 dollar toy
  235. Weird ABS light and power window problem
  236. Oil Leak Around IP Gear Housing
  237. 07 5.9 black smoke
  238. Twin Traction Beam Questions
  239. whats this wire for?
  240. new exhaust
  241. 6.9 not starting
  242. crazy white smoke and backfiring
  243. 94 7.3 IDI Turbo Diesel Black Smoke and Engine knock
  244. question about a 1992 diesel
  245. seems gutless....
  246. where to get a fuel heater for a 7.3?
  247. Pre-purchase checklist
  248. Truck started stalling. Need advice
  249. Need physical size of a 6.9 / 7.3 idi
  250. fuel selector switch
