- auto trans temp sensor location
- Bad Miss no accel
- cold engine protection on edge juice w att
- Methanol injection By Snow performance??
- idea for build up
- TWIN QUESTIONS
- BD stealth plate
- qUADZILLA Adrenaline burnt?
- Whats the difference?
- Fuel Injectors ? Nozzles ?
- a REAL jake brake :)
- Tranny filter
- guage suggestions and lift pump suggestions
- too much timmin
- What injectors to go with
- hx35/40 hybrid
- Edge Comp Quit Working!!!!!!!!!
- RAPTOR OR AIRDOG?
- Lope at Idle
- 5 Inch Exhaust
- raptor problem
- cant get fuel line off of tank for raptor install
- what am i missing?
- max fuel pressure?
- New Turbo!
- High hp question...
- raptor 150 install question
- cooling system
- Hot rod vp44
- 80 HP Injectors
- just cant firgure it out
- I want to know.
- Adding a 3rd Gen track bar conversion
- edge juice
- dropping the tank
- trans. shop??
- 47re shop ?
- Adrenaline surge
- is it worth my time to swap turbo housings?
- 6 speed swap to auto! help
- Smoke Switch Help!
- TC Lockup Switch Help
- to much turbo
- quadzilla updates
- pyro spike?
- Leveling Kit
- injectors
- fass ddrp lift pump pressures?
- Laggy HE351 with plenty of fuel???
- oil pressure gauge
- Newbie needing advice
- Programmers
- CAT filter??
- New User (HELP)
- New turbo
- Rewired lift pump
- which lift pump should I go with???
- Adrenaline Pulse Readout
- Stack Bed Kit Cover
- trans. prob.
- EGT how hot is too hot?
- problems with bd stealth plate
- Cabin Filter
- gauge mounting
- adrenaline tunes
- 150's
- Stacks w/ muffler
- tst
- fuel press gauge mounting location
- Edge Comp questions
- trans question
- 2000 cummins
- install of nitrous 150 shot!!
- motor cuts out.
- Stack Mounting bracket help
- Blew my Trans today!
- injection lines
- 250's super B special 4K tune!
- Swamping in a 3rd gen sway bar.
- Orings and studs
- Dual Disk clutch
- Stack Installation
- vp44 longevity
- Raptor 95, 100 or 150
- edge drag comp box help
- runnin the valves
- htt upgrade compressor
- 98.5 tuners
- Dynamite Injectors
- Edge Juice w/Attitude Question
- Industrial Injection Super Dragon Flows
- New Turbo Setup
- Stack Mufflers?
- New guy needs a swift kick in the a$$
- P-pump Swap pics
- Twin help
- random thanks
- Stacks
- twins
- new turbo and still high egts?!?!
- hellman performance sump!
- jwa fuel pressure sensor
- Transfer Pump
- 02 what do i need
- how can i tell?
- pinching off waste gate line on stock turbo
- left overs from juice install
- p-pump or monster vp
- s300 turbo leaking
- FBD injectors
- D-tech turbo \ Fireball injectors
- raptor 150
- What Next?
- Custom Compound Turbo Setup Need Opinions PLEASE!
- new pyro where to tap exhaust manifold?
- NV4500 Clutch
- Fass ddrp or Air Dog 150?
- Running Too High EGT's - Water/Meth?
- Mighty Diesel's Houdini Head Bolts Install Images
- i think an adr problem
- Aftermarket Exhaust Manifold - Heater Core Line
- building injectors
- edge jwa
- best turbo
- Stacks?
- upgrades begin
- clutchless shifting
- check engine light??
- Best Turbo and Injector setup?
- Need to replace my BHAF
- Improving what I have?
- Can I make my D60 a full floater?
- how much difference?
- P pump or twins??
- Edge comp and Hypertech tuner
- TRANZ
- fabricating???
- Edge Juice with attitude cs/cts
- Edge JWA
- boost elbows?
- Time for head studs?
- TRIPPLE STACKED?
- Adrenaline with pulse
- 01 Cummins 24 valve
- ScanGaugeII - by Linear Logic LLC
- whats the best trans for 99 cummins
- smarty vs edge juice w/attitude
- Programmers, Foolers, Mods, what's the best for the buck?
- raptor vs airdog
- good setup?
- Need some help?
- new injectors?
- Quadzilla Learning?!
- stage 1 24 valve build up!
- HX35, HX40... Is it worth it?
- Raptor 150 or 100
- injectors
- Southbend Vs. Valair
- high egts or not?
- Summer BOMBS
- Interesting
- got my new stuff!!!!
- Industrial Injection silver 62
- xx fuel filter systems.
- Raptor 150
- New parts!
- best chip/programmer
- programmers for 02 cummins
- injectors turbo combo
- New twins
- Fass DDrp Fuel Pressure?
- Starting out
- S 475 Info
- Upgrade info
- How did you mount your edge juice?
- fuel pressure sender
- eletric cooling fan
- ddp 40s
- short shifter setup for NV4500
- EGT'S safe or not!!
- slap shifter
- Tapping the pump
- AD install...
- nv4500 trans temp gauge?
- Torque Converter
- Best turbo?
- adrenaline 4k questions
- clutch problems
- edge juice w attitude or quad w pulse
- fass ddrp pressure?
- Chip It or Program It. Safe with a Stock Tranny?
- bd 64mm power special vs aurora 3000
- 8.3 hx40
- I need a little turbo help
- edge jwa or comp box
- nitrous!!!
- pulse
- injection lines/cross tubes??
- tapping pump?
- Best aftermarket vp?
- Stacking on top of a Quadzilla Adrenaline
- Injectors
- Installing a fuel pressure gauge
- chip question
- tractor turbo
- stacks or sidewalk smoker
- edge comp setting?
- question about goerend
- edge comp and codes?
- smoke switch
- where can I find new injector line nuts
- comp box with fass ddrp lift pump?
- Edge Comp Box?
- fuel pressure
- Programmer
- Hamilton 110lb valve springs
- Smarty???
- fass 95 pressure an mods
- comp or smarty?
- fooler
- surging under hard load
- Leaking Big Line Kit At The Fuel Gauge Fitting. Ideas?
- Dodge Cummins 6 Speed Clutch Install Video Clips
- smarty power levels
- where to buy airdog 150 filter
- quadzilla xzillaraider
- Boost PSI runnin Quad Adr
- fuel pressure gauge
- Hot Unlock buy it of not??
- twin turbo setup
- fass or airdog??
- hx40 explosion
- FASS
- hx40 boost
- hx35 vs hx40
- quadzilla ADR tourqe tune!!!!
- curiosity
- connector tubes
- Dr. Performance Module
- $10,000 bucks! Hmm, What to do?
- Fireball 150's idle
- garrett turbo
- Stackable Programer Combo Guide
- transmission options
- air intake
- injectors
- air dog 150 filter
- Injector lines
- Smarty Edge EZ stack?
