- cummins shopping
- 2000 Ford 12v conversion pics.
- 1/2 ton 4X4 diesel conversion for sale?
- Common Rail Wiring
- It's alive!
- Just another Fummins with lots of pics!
- Nissan Hardbody 3.9 swap
- My '93 Fummins
- Cherokee OM617 Swap
- Worth the headaches?
- 03 commom rail - 12v w/ P7100
- Is 25mpg/city possible in a full size pickup?
- gas/diesel conversion
- allison speed sensor wiring
- dt466 conversion
- 37 GMC Cummins
- Anyone done a late model Chevy Cummins conversion?
- Mercedes 240/300 in S10?
- 99 ram 1500 gas to diesel swap.
- 1986 gmc diesel conversion
- 89 GMC V3500 454 to 95 Cummins
- 01 Ram 1500 Gas to Diesel?
- 95 v10 dodge auto to 1st gen swap
- cummins eater
- what engine for a 91 7.3idi
- Here is my conversion
- 97 F350 Engine Swap... NEED HELP!!
- Here's my diesel conversion
- weight of a 4bt
- 99 powerstroke to cummins?
- Mercedes Into a Jeep
- 71 Chevelle Cummins transplant t56
- Dodge V10 to Cummins?
- 94 P30 6.5na to 5.9 CTD
- Latest Conversions Completed
- gas to diesel question
- 4bt into 97 Dodge 1500
- 47re to nv5600 swap
- project pugg
- Humvee Cummins Conversion
- 86 K20 Swap to 5.9
- S-10 conversion
- Fuller,Spicer,Allison trans conversion parts list!!!
- 2000 f150 gas to diesel conversion
- 400 Big Cam Cummins in Chevy Kodiak
- 2000 dodge 2500 360 gas to diesel
- IH 436 combine engine in a F350
- trans swap
- finally got my 1st gen cummins in my 95 k2500 chevy!!! PICS
- 1993 cummins in 1995 chevy k2500
- Convert Cummins 5.9L from VP44 to common rail?
- Staying with the V10...not happy!!!!
- need help!
- 01chevy diesel swap?
- 87 suzuki samurai to vw 1.6td swap
- Another Mercedes OM617 into a Wrangler
- 05 f-350 EGR cooler delete
- 96 powerstroke into 01 3/4 suburban
- 4bt into... help me decide
- 1980 k20 diesel swap wat kind of tranny
- Converting C70 Chevy (366 gas) to 5.9L
- 5.9 in a 93 f250
- ISUZU NEEDS MORE POWER
- cummins 12 valve in chevy k1500. frame problems????
- 64 gmc conversion
- Diesel Mud Buggy
- intercooler questions?
- 2002 Ranger conversion to a 4BT?
- F350 conversion
- gas to diesel 2000 dodge 2500
- 1998 GMC 6.5 diesel
- 2005 Ford Super Duty - The Perfect Swap
- 12 valve cummins in an 88 chevy 1500 short bed stepside
- swap an 2001 LBZ into a 2001 gasser?
- 250 into a 150?!?!?!?!
- 97 powerstroke convert to 2000 motor and computer
- Diesel Conversion For F-150
- new to diesels looking for information
- 8.3 Cummins in a "pickup"
- DT466 in a GMC 3500HD
- i'm a dumbass, an a newbee to diesel's
- 93' chevy 3500 cummins swap
- 2001 Jeep Cherokee want a 4bt in it
- 96 F-250 Common Rail?
- cummins swap
- cummins swap
- 93 chevy 1 ton/5.9 cummins
- 1st generation cummins
- early chevy 5.9 swap
- OM617 to NV3550
- chevy idea/help
- 1968 Corvette Diesel
- 2001 cummins automatic trans conversion
- any other adapter mfg's
- Dodge V10 to Cummins Swap
- 94 F150 CONVERSION--
- F150 CONVERSION--
- 5.4 Triton 4BT Cummins swap?
- Cummins in cherokee?
- need 4bt cummins
- Shifter stick
- "Reverse Conversion"
- Kubota 3 cylinder industrial engine conversion
- motor mount id part number help?
- 4bt cummins in s-10
- 95 chevy front drive shaft ideas..options...
- 12 Valve into a 1999-2003 F350 ?
- 84 6.2 liter diesel to 97 3/4 ton chevy swap
- 4BT Slave/Master Problem
- 72 K20 LB7 4x4 D-Max Update
- 6bt in a buick regal?
- swapping 6.9 or 7.3 in 78 FORD f-250
- 6.5 to cummins conversion?
- Chevy/Cummins swap
- Engine Adapter is there any interest ???
- Chevy body on a dodge frame
- Pcs Transmission controller
- Back 2 The Future 5.9 Cummins
- Mits. 4D56TD Swap
- Swap a 04.5 5.9 Cummins for a first or second gen.
- in know this has been done before
- 12 valve bronco swap
- 87 jeep wrangler (617 coversion)
- will a Dana 300 last?
- newly aquired engine
- which t-case to use
- 2 wheel 1/2 ton cummins
- Needed Cummins
- 85 chevy 1ton cummins
- cummins in half ton
- 79' chevy k20 conversion...Help!
- gas and diesel firewall
- 4bt FRANKENJAEEP
- This Truck Is Sweet
- 2001 Chevy 2500HD conversion
- So many ideas, so little money.
- 6.0 cutting out
- check this out
- Call me 6.7l crazy
- The Fodge update
- 1991 Dodge 350 van swap
- 4BT in W100
- Allison automatic trans for Cummins
- Cummins in a GMC
- Cummins In 05/06 Chevy or GMC?
- 72 K20 4x4 + LB7 Duramax motor
- Progress on the 78 Ford Cummins
- Diesel Engines for sale
- 4bt Conversion
- Thermo King 4 cylinder(Isuzu)
- Diesel bronco
- Kubota Ranger Swap
- cummins in a chevy
- Outlaw Diesel is out of their mind.
- 4bt Cummins Rat Rod??
- 1971 Chevy K-20 Cummins Project.
- lots of ?'s and need lots of ideas
- 1998 ford f-150 4x4 lariat from 4.6 triton to cummins 4cyl diesel
- Sweet Conversion!
- Bradley GT Diesel
- Looking for DT466/530 swap info
- is it possible
- '95 F350 Engine Swap
- new project
- what diesel should i use?
- 6.5 TD into an 85 Yota
- 3208 cat in chevy
- Toyota MR2 Diesel
- Diesel Jeep Ideas
- gmc 1500 hd to duramax
- Need to set things straight
- ENGINE SWAP
- Didnt think this would work
- Cummins 10 speed conversion
- Mercedes Diesel To GM trans??
- NV 4500 QUESTION
- M11 Cummins
- Detroit Diesel Rail Car
- Duramax Powered Buick GNS
- My Project
- In Search Of A Donor For A "Heart Transplant"
- Gear Ratios And Ultimate Speed
- '92 VW 1.6L Diesel
- Mercedes OM617
- Van Conversion
- Diesel Vette
- 1994 F-150 4x2 Automatic Transmission
- 1994 K1500 6BT SWAP
- 12V In A '71 Ford?
- 1976 Ford Bronco Conversion
- Common Rail Swap Into A '99
- Jeep 2.8L Diesel Conversion Kit
- 4BT Cummins
- 7.3 IDI Intercooled Turbo in 90 Bronco
- 1947 Ford 1.5 Ton 'Heavy' W/ A Cummins
- Similar Frames?
- 1972 Chevy K20
- Jeepster Commando 4BT
- REAL Jake on a 5.9
- 1976 F350 with a 1160 Caterpillar....
- ANYONE DONE A PERKINS CONVERSION?
- 1995 K2500 Cummins
- 1966 Ford Bronco - Buckin' Bronco
- Switch Engines
- Cummins 4BT In Foxbody Mustang
- Any Tech Info On Hot Rodding A 4BTA
- 7.3 Powerstroke Swap
- 1977 GMC K3500 - Built To Suit
- Ford/Cummins/Allison.....New Project........
- Cummins/ Allison Combo
- Chevy Cummins
- Red Chevy With 7.3 Powerstroke Pulling...
- 2007 Jeep Wrangler Rubicon JK 5.9L Cummins - The Ultimate Diesel Jeep
- 1500 Chevy Duramax??
- Pic ?
- VW In An S10/Ranger...?
- Chevy Cummins Conversions, Check In Here
- Anybody See The Twinned Ranger?
- F150 Gas To Diesel Conversion
- Sweet Conversion Project
- The Doubler™ Is An All Gear, Dual Transfer Case System
- DT466 In A OBS Stroker?
- DT466 School Bus Conversion
- 6bta = High MPG?
- 68 Bronco
- 1982 Buick Regal - Darth Vader: Diesel Alternatives
- Diesel Samurai Conversions
- Cummins Vete????
- Cummins Motor Mounts
- Duramax In A 88-99 GM Truck
- Advanced Adapters Website
- 6V-53T And A 5 Speed Allison
- Detroit Diesel Conversions
- Motor Swap
- Cummins 3.9 4BTA In 1500 Dodge MPG
- 1991 Cummins
- What To Look For In A Wrecked Truck
- Dakota + 800 HP Commonrail
- Class 8 Dodge Ram..Heheheh
- Cummins 3.9 4BTA In 1994 Dodge Ram 1500
- Where to get a motor?
- anyone got $15000
- gas convert to diesel
- HOWS THIS FOR A SWAP
- 90's Chevy cummins converts
- 95 Dodge 2500 360 To Cummins Swap
- Cummnis 3.9
- Dodge 1500 318-6BT Conversion
- Here is one for the Dmax guys (GNX clone)
- Diesel monte carlo!!!○
