PDA
View Full Version : Diesel Engine Conversions
Pages : 1 2 3 4 5 6 [7]
  1. 97 powerstroke convert to 2000 motor and computer
  2. Diesel Conversion For F-150
  3. new to diesels looking for information
  4. 8.3 Cummins in a "pickup"
  5. DT466 in a GMC 3500HD
  6. i'm a dumbass, an a newbee to diesel's
  7. 93' chevy 3500 cummins swap
  8. 2001 Jeep Cherokee want a 4bt in it
  9. 96 F-250 Common Rail?
  10. cummins swap
  11. cummins swap
  12. 93 chevy 1 ton/5.9 cummins
  13. 1st generation cummins
  14. early chevy 5.9 swap
  15. OM617 to NV3550
  16. chevy idea/help
  17. 1968 Corvette Diesel
  18. 2001 cummins automatic trans conversion
  19. any other adapter mfg's
  20. Dodge V10 to Cummins Swap
  21. 94 F150 CONVERSION--
  22. F150 CONVERSION--
  23. 5.4 Triton 4BT Cummins swap?
  24. Cummins in cherokee?
  25. need 4bt cummins
  26. Shifter stick
  27. "Reverse Conversion"
  28. Kubota 3 cylinder industrial engine conversion
  29. motor mount id part number help?
  30. 4bt cummins in s-10
  31. 95 chevy front drive shaft ideas..options...
  32. 12 Valve into a 1999-2003 F350 ?
  33. 84 6.2 liter diesel to 97 3/4 ton chevy swap
  34. 4BT Slave/Master Problem
  35. 72 K20 LB7 4x4 D-Max Update
  36. 6bt in a buick regal?
  37. swapping 6.9 or 7.3 in 78 FORD f-250
  38. 6.5 to cummins conversion?
  39. Chevy/Cummins swap
  40. Engine Adapter is there any interest ???
  41. Chevy body on a dodge frame
  42. Pcs Transmission controller
  43. Convert Ford E350 10cyl to Diesel??
  44. Back 2 The Future 5.9 Cummins
  45. Mits. 4D56TD Swap
  46. Swap a 04.5 5.9 Cummins for a first or second gen.
  47. in know this has been done before
  48. 12 valve bronco swap
  49. 87 jeep wrangler (617 coversion)
  50. will a Dana 300 last?
  51. newly aquired engine
  52. which t-case to use
  53. 2 wheel 1/2 ton cummins
  54. Needed Cummins
  55. 85 chevy 1ton cummins
  56. cummins in half ton
  57. 79' chevy k20 conversion...Help!
  58. gas and diesel firewall
  59. 4bt FRANKENJAEEP
  60. This Truck Is Sweet
  61. 2001 Chevy 2500HD conversion
  62. So many ideas, so little money.
  63. 6.0 cutting out
  64. check this out
  65. Call me 6.7l crazy
  66. The Fodge update
  67. 1991 Dodge 350 van swap
  68. 4BT in W100
  69. Allison automatic trans for Cummins
  70. Cummins in a GMC
  71. Cummins In 05/06 Chevy or GMC?
  72. 72 K20 4x4 + LB7 Duramax motor
  73. Progress on the 78 Ford Cummins
  74. Diesel Engines for sale
  75. 4bt Conversion
  76. Thermo King 4 cylinder(Isuzu)
  77. Diesel bronco
  78. Kubota Ranger Swap
  79. cummins in a chevy
  80. Outlaw Diesel is out of their mind.
  81. 4bt Cummins Rat Rod??
  82. 1971 Chevy K-20 Cummins Project.
  83. lots of ?'s and need lots of ideas
  84. 1998 ford f-150 4x4 lariat from 4.6 triton to cummins 4cyl diesel
  85. Sweet Conversion!
  86. Bradley GT Diesel
  87. Looking for DT466/530 swap info
  88. is it possible
  89. '95 F350 Engine Swap
  90. new project
  91. what diesel should i use?
  92. 6.5 TD into an 85 Yota
  93. 3208 cat in chevy
  94. Toyota MR2 Diesel
  95. Diesel Jeep Ideas
  96. gmc 1500 hd to duramax
  97. Need to set things straight
  98. ENGINE SWAP
  99. Didnt think this would work
  100. Cummins 10 speed conversion
  101. Mercedes Diesel To GM trans??
  102. NV 4500 QUESTION
  103. M11 Cummins
  104. Detroit Diesel Rail Car
  105. Duramax Powered Buick GNS
  106. My Project
  107. In Search Of A Donor For A "Heart Transplant"
  108. Gear Ratios And Ultimate Speed
  109. '92 VW 1.6L Diesel
  110. Mercedes OM617
  111. Van Conversion
  112. Diesel Vette
  113. 1994 F-150 4x2 Automatic Transmission
  114. 1994 K1500 6BT SWAP
  115. 12V In A '71 Ford?
  116. 1976 Ford Bronco Conversion
  117. Common Rail Swap Into A '99
  118. Jeep 2.8L Diesel Conversion Kit
  119. 4BT Cummins
  120. 7.3 IDI Intercooled Turbo in 90 Bronco
  121. 1947 Ford 1.5 Ton 'Heavy' W/ A Cummins
  122. Similar Frames?
  123. 1972 Chevy K20
  124. Jeepster Commando 4BT
  125. REAL Jake on a 5.9
  126. 1976 F350 with a 1160 Caterpillar....
  127. ANYONE DONE A PERKINS CONVERSION?
  128. 1995 K2500 Cummins
  129. 1966 Ford Bronco - Buckin' Bronco
  130. Switch Engines
  131. Cummins 4BT In Foxbody Mustang
  132. Any Tech Info On Hot Rodding A 4BTA
  133. 7.3 Powerstroke Swap
  134. 1977 GMC K3500 - Built To Suit
  135. Ford/Cummins/Allison.....New Project........
  136. Cummins/ Allison Combo
  137. Chevy Cummins
  138. Red Chevy With 7.3 Powerstroke Pulling...
  139. 2007 Jeep Wrangler Rubicon JK 5.9L Cummins - The Ultimate Diesel Jeep
  140. 1500 Chevy Duramax??
  141. Pic ?
  142. VW In An S10/Ranger...?
  143. Chevy Cummins Conversions, Check In Here
  144. Anybody See The Twinned Ranger?
  145. F150 Gas To Diesel Conversion
  146. Sweet Conversion Project
  147. The Doubler™ Is An All Gear, Dual Transfer Case System
  148. DT466 In A OBS Stroker?
  149. DT466 School Bus Conversion
  150. 6bta = High MPG?
  151. 68 Bronco
  152. 1982 Buick Regal - Darth Vader: Diesel Alternatives
  153. Diesel Samurai Conversions
  154. Cummins Vete????
  155. Cummins Motor Mounts
  156. Duramax In A 88-99 GM Truck
  157. Advanced Adapters Website
  158. 6V-53T And A 5 Speed Allison
  159. Detroit Diesel Conversions
  160. Motor Swap
  161. Cummins 3.9 4BTA In 1500 Dodge MPG
  162. 1991 Cummins
  163. What To Look For In A Wrecked Truck
  164. Dakota + 800 HP Commonrail
  165. Class 8 Dodge Ram..Heheheh
  166. Cummins 3.9 4BTA In 1994 Dodge Ram 1500
  167. Where to get a motor?
  168. anyone got $15000
  169. gas convert to diesel
  170. HOWS THIS FOR A SWAP
  171. 90's Chevy cummins converts
  172. 95 Dodge 2500 360 To Cummins Swap
  173. Cummnis 3.9
  174. Dodge 1500 318-6BT Conversion
  175. Here is one for the Dmax guys (GNX clone)
  176. Diesel monte carlo!!!○
  177. 12V Into Dually Chevy CC (Pics Inside)
  178. Who Has One ?
