- ford/cummins
- what engine to use
- Update on progress
- 89 Suburban 4x4 2500 CTD
- cheap 12v to superduty swap
- Transmission help
- 12v to 24
- 12 valve vs. 6.5 swap
- 95 Chevy 2500 questions
- F350 Cummins conversion
- 85 K5 blazer 12v swap
- 73 d100 cummins not mine but wish it was
- 4BT Minivan?
- what would be the ultimate diesel pickup for you?
- Destroked motor mounts
- 4bt ranger
- ISB 4bt into 04 F-150
- Monte Carlo Cummins
- Cramming a Cummins ISX under a ford hood..
- Transmission Controllers
- 2004 Ford Excursion 5.4 to 6.0 diesel
- 4bt in a 94 toyota?
- Best cummins to go in 1996 c3500 5speed
- 4bt swap
- chevy cummins
- exhst manifold quest
- cummins valve covers ??
- Conversion?
- Ford Excursion Conversion links?
- Slow boost response
- 99 Powerstroke Conversion
- nv4500 to a 205 transfer case?
- 1994 F-250 4x4 6BT Cummins Swap
- What do i need?
- nv4500hd conversion
- 05' Nissan Titan 5.9 Cummins
- j10
- Can anyone help me out on a cummins question?
- Anyone using the Nissan 6cy TD out of a UD mediun duty truck?
- I want to swap 392 for diesel!!!!!
- cummins b3.3 performance upgrade? f150?
- 6.9 Conversion Questions..
- first gen 12v transmission questions
- an odd project
- future swap
- Gettin' it together,,,
- will a bell housing off a 360 gas bolt on a 1 st gen
- 8.3 Cummins ino a topkick HELP!
- cummins swap kustom parts for a ...
- 01 f150 4bt swap as original as possible
- What Cummins is best?
- 1967 Chrysler Imperial w/6BT
- 12v into 2003 ford 350
- '74 7.3 idi?
- Deutz 4
- Curious if anyone else has heard about doing this or done it?
- Please Help me out here
- Tachometer Question on 6bt swap
- 85chevy swb 12 valve swap!
- 4bt in a 656 farmall?
- Engine Alignment and Spacing
- Diesels are not all equal...
- 85 3/4 ton suburban needs a 7.3!
- 99 f150 gettin a 7.3
- My Bronco cummins conversion (work in progress)
- 99 v10 installing 97 12-valve cummins
- A/C compressor pulley
- fordcummins parts
- What 5.9 set up to use?
- New member and my project 39
- 4bt powered FJ60
- Vacuum pump clearance issues
- 01 f350 cummins conversion
- Older Cummins in an 03 Ram
- HELP rpm sensor info?
- convert a Getrag 2wd to 4wd
- Clutchless
- Yanmar ???
- 95 cummins tach hook up
- FWD 4.3L V6 into a 4WD Cherokee
- Cummins/Allison 545
- 4bt into a 1970 thru 1980 fullsize wagoneer
- Duramax \ El Camino
- 2003 Ford 5.4L 7.3 Conversion?
- 98 ford 4BT wannabe
- 86 Cherokee OM617/700R4/NP231
- 1st Gen Powerstoke into a 92 Chevy C3500?
- Ford Cummins tranny and transfer case issue
- jeep cummins conversion
- 1932 ford model b project
- fummins speedometer cable
- SD-22 nissan diesel into mitsubishi mighty-max 4X4
- Planning a cummins Conversion
- 1978 Jeep Cherokee, looking for conversion ideas/suggestions
- nv4500
- a/c condensor
- How much hp can stock trans handle?????
- Hey guys and gals!
- 96 v10 to 12v
- possible perkins conversion here
- Planning a Fummins
- duramax 7800 in 94 chevy 3500 help please
- 84 Dodge W150 4BT swap
- 4bt in s-10
- Dirtymax Fox Mustang
- 59 Plymouth Belvedere Diesel swap?
- April issue of Diesel World Magazine
- Mercedes OM617 to 700R4 adapter plates?!
- V10 to Cummins conversion w/ Automatic trans.
- 1990 soon to be powerstroke...
- 6.0-12v
- 99 GMC HD3500 5.9 Cummins 9 speed
- 71 chevy k10 12 valve swap?
- 1992 F250 4x4 Cummins Conversion
- p7100 fuel pump ?
- 89 blazer engine swap to 93 12v
- just a question?
- 95' Cummins 5.9 into 75' Ford swap, Auto tranny questions-
- 1990 f-250 4x4 cummins swap
- duramax transplant 55 chevy
- dt466 transmission
- 2001 Ram Conversion
- 24v internals in a 12v block
- 99 dodge wont start
- F-550 CUMMINs
- 96 dodge v10 to 12 valve
- 1991 quad cab chevy 1 ton 4x4
- 1951 International swap
- 6 speed to an Allison.
- Any body know about old Allison's?
- 92 F-350 Cummins swap
- 95 12 valve into 92 chevy
- Diesel Engine Swap In My Bar Stool Racer...
- 12 valve in a swb dodge 1/2 ton
- 350 Flywheel on a 6.2?
- Perkins 4.236 in 75 Range Rover
- how much and how long?
- 93 cummins turbo swap with a 96 cummins
- putting a Cummins in my old Chevy
- 1966 ford truck ..... 12 valve swap
- NEED HELP!!!
- 92 chevy 12 valve swap
- 97 gas v8 to 99 cummins
- Ideas for engine swap for Bronco
- 1991 ford cummins conversion
- need opinion 24v swap
- 96 ram body and wiring shot, can i swap a 1500 body ?
- 04 chevy 2500hd cummins conversion
- powerstroke mustang
- 1995 Ford-Cummins 12 valve swap???
- cummins 1st and 2nd gen to allison 1000
- gen 1 in 99 24 v
- Gen 1 in a 95 ram v10
- two many irons not enuf fires
- NV4500 input shaft
- swap my 12V into my 03 1500
- 77 Ford wants cummins power
- ranger 6bt or 4bt
- Bye bye triton
- My Cummins swap. Lots of pictures
- 92' Cummins in a 1 Ton Chevy
- Ford county to cummins?
- 6.9L Ford Marinization?
- GMC 2500 HD 6.0 Gas Conversion to Diesel
- swaping motors
- diesel bronco help
- gas to diesel swap
- New Engine
- 1969 Ford Crew Conversion....
- 06 dodge gas to diesel swap
- rotary or p-pump???
- question for the chevy cummins guys
- converison 89 s-10 to mb 603, need info.
- 1979 F-350 Resto-Cummins Swap. LOTS OF PIX!
- cummins shopping
- 2000 Ford 12v conversion pics.
- 1/2 ton 4X4 diesel conversion for sale?
- Common Rail Wiring
- It's alive!
- Just another Fummins with lots of pics!
- Nissan Hardbody 3.9 swap
- My '93 Fummins
- Cherokee OM617 Swap
- Worth the headaches?
- 03 commom rail - 12v w/ P7100
- Is 25mpg/city possible in a full size pickup?
- gas/diesel conversion
- allison speed sensor wiring
- dt466 conversion
- 37 GMC Cummins
- Anyone done a late model Chevy Cummins conversion?
- Mercedes 240/300 in S10?
- 99 ram 1500 gas to diesel swap.
- 1986 gmc diesel conversion
- 89 GMC V3500 454 to 95 Cummins
- 01 Ram 1500 Gas to Diesel?
- 95 v10 dodge auto to 1st gen swap
- cummins eater
- what engine for a 91 7.3idi
- Here is my conversion
- 97 F350 Engine Swap... NEED HELP!!
- Here's my diesel conversion
- weight of a 4bt
- 99 powerstroke to cummins?
- Mercedes Into a Jeep
- 71 Chevelle Cummins transplant t56
- Dodge V10 to Cummins?
- 94 P30 6.5na to 5.9 CTD
- Latest Conversions Completed
- gas to diesel question
- 4bt into 97 Dodge 1500
- 47re to nv5600 swap
- project pugg
- Humvee Cummins Conversion
- 86 K20 Swap to 5.9
- S-10 conversion
- Fuller,Spicer,Allison trans conversion parts list!!!
- 2000 f150 gas to diesel conversion
- 400 Big Cam Cummins in Chevy Kodiak
- 2000 dodge 2500 360 gas to diesel
- IH 436 combine engine in a F350
- trans swap
- finally got my 1st gen cummins in my 95 k2500 chevy!!! PICS
- 1993 cummins in 1995 chevy k2500
- Convert Cummins 5.9L from VP44 to common rail?
- Staying with the V10...not happy!!!!
- need help!
- 01chevy diesel swap?
- 87 suzuki samurai to vw 1.6td swap
- Another Mercedes OM617 into a Wrangler
- 05 f-350 EGR cooler delete
- 96 powerstroke into 01 3/4 suburban
- 4bt into... help me decide
- 1980 k20 diesel swap wat kind of tranny
- Converting C70 Chevy (366 gas) to 5.9L
- 5.9 in a 93 f250
- ISUZU NEEDS MORE POWER
- cummins 12 valve in chevy k1500. frame problems????
- 64 gmc conversion
- Diesel Mud Buggy
- intercooler questions?
- 2002 Ranger conversion to a 4BT?
- F350 conversion
- gas to diesel 2000 dodge 2500
- 1998 GMC 6.5 diesel
- 2005 Ford Super Duty - The Perfect Swap
- 12 valve cummins in an 88 chevy 1500 short bed stepside
- swap an 2001 LBZ into a 2001 gasser?
- 250 into a 150?!?!?!?!
