PDA
View Full Version : Diesel Engine Conversions
Pages : 1 2 3 4 [5] 6 7
  1. 78 Camaro and 6b
  2. My 92 YJ OM617 swap
  3. The latest FNG... pardon my ignorance, need advice.
  4. HELP CUMMINS STARTER NOT MATTING UP
  5. cummins swap trann questions
  6. NV4500 to ford transfer case?
  7. boxing 1978 Bronco frame for Cummins swap?
  8. oM617 OIL COOLER ?
  9. Are there any turbo oil feed/supply line upgrades for mercedes 300Ds?
  10. What adapter for a 0M671 to AX15
  11. 6.0-6.4
  12. Shorten NV 4500 output shaft
  13. Adjusting Boost on Om617
  14. '95 V-10 Swap to 12 Valve
  15. Idea for new engine
  16. Gearing for OM617 in my 95 S10
  17. 95 fummins
  18. convert to cable from original throttle linkage...
  19. 12 Valve into a 94 Chevy 1/2 ton
  20. Fummins A/C guys out there...
  21. OM603/606 vs 617... vs Jeep Gasoline 4.0L I6 or 5.2L V8
  22. Cherokee OM617 steering questions
  23. destroked vs. fordcummins.com
  24. 99 dodge 2500 360v8 for cummins
  25. decision time - oil coolers necessary?
  26. Oil Tube to oilpan on om617
  27. Transfercase ford cummins question
  28. Duramax in a 350?
  29. Swap Suggestions / Concerns ? OM617 - AX-15
  30. What do you think of a 700r4 to OM617 ..
  31. Cummins to chevy adaptor plate
  32. conversion planning stages questions
  33. OM167 Sensor on Intake
  34. 96 Cherokee with OM617 Diesel Conversion Swap
  35. Is the ford cummins exhaust manifold for 12 valves just an industrial manifold
  36. Will 617 Mercedes eat my yota R150?
  37. 6.5 t/d to gas
  38. 12v p pump with allision 545 fummins
  39. The Ford Currier build!
  40. Which would you Choose? 6.2 or 6.5
  41. damaged a couple of parts 0m617
  42. single blt om617
  43. Errors are avoided with good advice.
  44. Should I convert?
  45. 6bt intercooler
  46. Cummins 24 V into 96 K3500 best question ever
  47. f-150 stock tach help,
  48. allison trans with a cummins
  49. 1978 Ford bronco, 12V cummins
  50. 1952 Ford F3 Cummins
  51. My FJ60 Cummins 6BT Conversion
  52. Mercedes Diesel to Jeep
  53. Mercedes in 95 S10 will not shift gears
  54. 1937 Dodge Humpback Diesel
  55. Avalalanche Cummins? or LS1 Swap?
  56. Bring Power to a John Deere 3650 114hp TRAKTOR
  57. idi to powerstroke swap
  58. s10 mercedes om617 conversion
  59. 05 F250 conversion 12valve advice needed
  60. gas to diesel chevy
  61. Diesel Swap 99 4X4 360 - 6BT
  62. looking for a clutch and pressure plate from a 617 mercedes
  63. 77 Ford f150 shortbed cummins swap
  64. 92 7.3 idi to cummins 96 12v
  65. Return fuel from injectors
  66. 95 6.5T swapped into an 80's gasser
  67. quick question for the swappers
  68. OM617 repower vacuum questions
  69. Isuzu diesel?
  70. Ezgo and a kubota
  71. 1985 Chevy 1 ton Crewcab Cummins Swap
  72. my 89 fummins build
  73. OM617 Mercedes Diesel Modified Narrow Oil Pan
  74. 72 ford 360 to cummins
  75. mercedes 300d into a 98 s10
  76. chevy gas swapped for a dmax
  77. 05 common rail into 2000 f350!!!!!!!!
  78. Mercedes OM617 Diesel Engine Swap to Jeep Comanche Conversion
  79. '02 24V and V10 47RH into my F350
  80. GM 6.5/6.2 into a '04 E350SD??
  81. Glow Plug Indicator
  82. put the engine in and got a problem
  83. 07 Ford 6.0 to a 6.7 cummins. Kits Available?
  84. mounts
  85. 1991 S10 gauge wiring
  86. HELP
  87. Looking for CR in 2003 F250-550 pics
  88. Looking for some $ figures
  89. 98 chevy intercooler question
  90. Duramax in A surburban?
  91. engine to trans adaptor plate thickness
  92. 95 F350 12valve swap
  93. Power steering
  94. Getrag Help!
  95. 67 F-350 12V Cummins
  96. Diesel Swap ????
  97. hemi to cummins
  98. 5.9 to 6.7 swap
  99. Tach Question
  100. am I crazy
  101. '47 Ford One-Ton (lots of pictures)
  102. trans upgrade
  103. cummins 6bt into 75 f250 (getrag question)
  104. Cummins 5.9 1st gen into blazer swap
  105. 6BT DIESEL SWAP IN TO 95 BURB
  106. Home Built 12vsuperduty Motor Mounts?
  107. toyota van gas to diesel swap
  108. Dead horse? '94 12v into a 2000 silverado
  109. mercedes/toyota conv.
  110. 2000 Hummer H1 cummins swap
  111. Cummins swap into 6.5
  112. 96 F250 Cummins swap research questions
  113. 1968 chevy
  114. om616 jeep swap
  115. airdog and exaust help
  116. Allright Doing a 94 Fummins 250 whats the skinny
  117. transfer case question
  118. IH Scout 12V
  119. 1984 Ford Ranger 2.2L Perkins
  120. adapter plate
  121. Superduty 12v tach ?
  122. 94 chev 3500 12v swap
  123. 2wd Excursion cummins swap ?'s
  124. 89-93 cummins swap
  125. Blazer 89 cummins 93 motor mounts???
  126. Parts needed for repower on 95 chevy
  127. 12v p pumped cummins into 1969 charger
  128. Merced to gm auto trans. adapter,,
  129. wondering if cab and engine swap would work
  130. i'm confuzzled
  131. clutch
  132. 241 dhd to getrag
  133. 81 chevy 1 ton dump conversion PTO....
  134. Wiring for a 94 - 97 F350 Cummins swap
  135. I have a ? about a clutch for a Cummins
  136. need a duramax
  137. 12 valve going in a 62 Chevy 1/2 ton
  138. F150 Diesel ?
  139. Natural Gas Conversion
  140. maybe, i dont know
  141. OM617 pre-transplant advise
  142. Diesel engs. engine for a' 49 Chev. 1/2 ton?
  143. Jeep Wrangler to Mercedes Diesel OM617 Engine Swap Conversion Kit
  144. Advise on OM627 donor stripping
  145. which tranny ZF 5 or NV4500?
  146. 12v cummins swapped to a 93 f250
  147. recommend water separation filter?
  148. manual shutoff system?
  149. VW Golf swap to all mech diesel
  150. OM617 to chev pickup,conversions,,
  151. good ole truck
  152. 94 turbo idi into motorhome
  153. looking to relocate om617 oil-filter housing...
  154. 12 valve or 7.3
  155. 06 F150 cummins 4bt conevert
  156. Dakota Frame Strength?
  157. 1st gen cummins in 2nd gen truck
  158. 4B 4 Cyl. RARE Cummins Engine and SAE 3
  159. allison at545 torque conv. bolts
  160. Ford cummins tranny issues
  161. my first 12v conversion
  162. Mercedes OM617 Diesel Glow Plug Relay Wiring Schematic Diagram
  163. Nissan Titan diesel
  164. 12 valve to replace 6.9 IDI
  165. BMW E36 Compact getting a M57TUD30 transplant :)
  166. 12V swap
  167. 94 150 302 to a 4bt conversion?
  168. 03 7.3 to 96 12 valve
  169. chevy cummins swap
  170. swapping a 2003 6.0 to a 7.3
  171. looking to put a 12v or a 4bt in 90's ram van
  172. Need some thoughts
  173. how hard will this be
  174. 84 2wd Chevy dually, cant find info or pics on this swap. 93 Cummins n 5 speed
  175. Bye Bye 12V Helloooo 24V
  176. 6.7 to 5.9 swap?
  177. need help in picking a motor for swap?
  178. Easiest/Best SUV Cummins Conversion?
  179. 94extcab Ford Short box+DTA360+FSO 8406a+kingpin dana 60 etc...
  180. cummins in 2001 dodge 1/2 ton
  181. allison 545 swap ?
  182. 99 chevy 2500 4x4 recieving a 5.9 transplant
  183. '97 F350 4x4 Crew '97 12V P-Pump & G56 Build thread
  184. Perkins?
  185. My conversion.
  186. 1st generation 5.9 Cummins in a 1990 Chevy K2500
  187. 1978 Bronco + 1991 Cummins 6BT
  188. 84 chevy pick-up 6.2 to 6.5 help
  189. 12 valve to 05 F250
  190. 12 valve to '05 F250
  191. Fummins wanted
  192. California Smog for Conversions
  193. it's time for the Pinzgauer to eat a Diesel.
  194. i have a 2001 2500 with a 24v 5.9 wanna put it in my 1985 w150 can anyone help me
  195. What OPTIONAL gauges should I get?
  196. Hmmmm...Expedition Conversion...??
  197. 1957 Diesel Project
  198. My 4bt Rat Rod is getting there
  199. Mercedes OM617 5 cyl Turbo Diesel engine swap to Jeep Wrangler YJ conversion
  200. Need Advice, New to Diesel
  201. Cummins conversions
  202. OM617 Conversion Questions/I Searched/PICS
  203. My 4BTAA Powered 4Runner
  204. 77 DODGE W200-'97 CUMMINS 12V bta-'59 SUMB CHASSIS/TRANS/AXLES
  205. 92 Cummins in a Chevy Dually...
  206. What do you guys think???
  207. read before ford cummins conversion
  208. 10 speed??
  209. 24v in a 1st gen dodge w250
  210. clean 500 to 600 hp
  211. 4bt?
  212. Comanche LD28 project
  213. 2nd gen 12v into 98+ Dodge Questions!
  214. Help with wiring, 12v into ford please!
  215. cummins 12 valve 5 speed in a 69 chevy
  216. 7.3 idi non turbo to a 90's powerstroke?
  217. NJ swap laws
  218. Mercedes 300d 5cyl turbo swap
  219. 6bt into a 98 chevy 1500?
  220. Powerstroke to Cummins swap...
  221. Gas Guzzler
  222. 84 F-250; 351w/C6 to 6.9/T19
  223. Is this good a good idea?
  224. 97 Ram 2500 360 to 5.9 help
  225. 12v Dakota Poject build log
  226. 2002 Land Rover Discovery
  227. engine swap
  228. 85 K5 Diesel SWAP 6.5
  229. swap to standard
  230. 1st gen to a nv 4500
  231. Any of you willing to do a swap on my junk
  232. deciding on mercedes jeep swap
  233. street legal
  234. DT466 Pulling truck Build
  235. 12v swap into 94" GMC
  236. 6.0 to 7.3 swap
  237. New Clutch!!!!!
  238. 7.3IDI engine swap question
  239. help choosing a diesel for my '87 Jeep Cherokee
  240. howdy ya'll I'm new to site!
  241. NV4500HD to NP205
  242. Removing a cab 2004 F-150???
  243. Cherokee swap
  244. 4BTA, which O/D trans to use?
  245. Can Someone tell me everything I need for 6bt swap.
  246. V10 swaped with 05 5.9L CR cummins
  247. K & N reusable air filter question
  248. H1 Hummer Conversion
  249. WHAT MOTOR!!!!!
  250. 85 K5 Diesel Swap.
