PDA
View Full Version : Diesel In Distress - Support Ticket
Pages : [1] 2 3
  1. 03 duramax lb7 light white smoke at idle
  2. 2001 cummins low power!!!
  3. Need help bad
  4. 48re headache
  5. No Transfer case in Hayes, KS
  6. Bad fuel milage, too much oil, cracked injector body?
  7. 6.0 wont get up and go
  8. 1992 f350 7.3 won't start
  9. more problems
  10. ehh got some codes
  11. 95 Powerstroke surging on startup.
  12. Code PO254 and TST PowerMax3 On 98.5 Cummins
  13. 1990 7.3 hard starting cold
  14. leaking fuel injectors
  15. bluish white smoke
  16. '98 Ram 3500 with no 5th gear
  17. thermostats
  18. head gasket
  19. smoking and missing 92 cummins
  20. what could this be?
  21. help
  22. 7.3 4R100 tranny not shifting 3-4 until warm
  23. 1990 7.3
  24. wont idle and pours smoke
  25. Manhattan ? anyone close ?
  26. truck shuts off on hot unlock
  27. 2006 6.0L No Start
  28. 94 6.5 Chevy misfire and smoke
  29. 02 cummins leaking fluids
  30. 89 Shut down while driving - no start
  31. air in fuel?
  32. ElectricKickle problem
  33. Weak powerstroke!!!
  34. white smoke and miss
  35. couldnt fix it with a hammer .. must be electrical
  36. Help 96 7.3 fuel leak hard to start
  37. help
  38. White smoke even after warm up
  39. Help!! 2000 24v acting strange
  40. OIL COOLER END HEADERS CAPS
  41. injecter pump not pumping
  42. 94 7.3 E350 No Start
  43. 6.9 f250 85 pickup no start help
  44. Bad voltage
  45. P0087-p0540 on d-max
  46. 6.5 needs help!
  47. 12v not starting...replaced fuel lines,cleaned tank,no starting
  48. anyone ever rebuilt a power steering box
  49. Hard Shifting 48re
  50. Broke The Fitting To The Transmission to Cooler Line
  51. need help with throttle cable bracket on 47re
  52. Injection Pump Solenoid???
  53. Injector Pump Diaphram
  54. 911 need help asap!
  55. '92 Dodge Cummins with no charge from the alternator
  56. 93 7.3 no start w/out starting fluid
  57. Dual Battery Terminal Rreplacement
  58. FORD VAN WONT START
  59. 48RE A/T Trouble Codes (Diesel)
  60. HELP!!! 06 Seized on I-95 at FL/GA Border
  61. 12 valve not start
  62. Truck stuck in limp mode no matter what I do!!!!!
  63. Old Man's stuck on a haul in FL in the 06...
  64. 05 Cummins turbo noise
  65. 02 dodge trouble
  66. 96 powerstroke rough running
  67. 01 cummins not starting
  68. 98 47re stuck in gear
  69. black smoke
  70. Strange Code
  71. Possible cause for Cummins locked engine
  72. torque convertor lock up solenoid
  73. lock up problems
  74. Water in fuel light on
  75. overdrive....
  76. 12Valve breakdown
  77. OBDII Codes For 07.5-Cur 6.7 Diesels
  78. 01 dodge intercooler boot
  79. turbo help
  80. Blue smoke while engine is cold, no smoke going down the road.
  81. Neighbors are complaining about smoke.
  82. trouble codes
  83. 2006 Dodge Cummins CR w/ code P2146
  84. 99 4x4 cummins auto tranny issues
  85. O6 2500 Ram No A/C
  86. CUMMINS TROUBLE!
  87. dodge truck trans problem
  88. 99 7.3 shuts down when cold
  89. Need rear driveshaft
  90. Tie Rrod End?
  91. 95 f350 glow plugs????
  92. 2000 f250 will not start
  93. 2007 6.7 a/c issue???
  94. not sure what is going on
  95. 01 Duramax w/ low Oil pressure
  96. vp problem or something else?
  97. 7.3 problems currentley in the big house
  98. 12 valve cummins transmission problem (HELP)
  99. 03 dodge hard to start and surging
  100. Fuse blowing
  101. clutch trans problem!?
  102. Throttle sticking Help!
  103. stalling 1999 f350
  104. Cummins 48RE Problem with 1st gear
  105. Bad Vibration..
  106. 6.2 gmc dies under boost
  107. 93 6.5 wont start!
  108. MBRP Exhaust 97' F350 Problem!
  109. help help help!!!!
  110. Truck wont start / low voltage / WTF
  111. Billowing white smoke then stops
  112. No oil pressure
  113. Wastegate - Sucking air - 99 7.3 PS
  114. tranny electrical probs.
  115. 6.5 issue, not a problem yet...
  116. O/D Blows engine fuse
  117. 07 5.9 Cummins Cutting Out
  118. powerstroke in need of help
  119. no OD or lockup cummins
  120. 1996 e350 wont start
  121. '01 Dodge Diesel transmission will not shift into OD...Please help!!
  122. powerstroke ipr location
  123. tour bus 99 e-350 7.3 need one part
  124. white smoke again
  125. 2003 ford 6.0 no power ?
  126. 6.5 problems again
  127. 24 valve problem
  128. Leaking coolant 2001 Cummins
  129. Powerstroke - wont start
  130. hesitation/ stumble
  131. power steering pump fittings and plugs
  132. bad vibration between 1500 to 18000 rpms
  133. Perfromance trans won't shift at WOT
  134. '01 Cummins keeps dying
  135. brakes???????????????
  136. Help Please Exhaust Full
  137. 1995 Cummins Hard Start
  138. 99 F250 Starting Hard Getting Worse
  139. knocking
  140. still no go
  141. 1996 6.5L keeps dieing.
  142. 6.9 international wont start
  143. 24v wont hold charge??
  144. won't run
  145. gear oil leak
  146. 7.3 shut down while driving and will not start
  147. 2004 ford powerstroke 6.0 p2262
  148. 7.3 won't run when cold
  149. 1990 Dodge won't start, no crank
  150. lining up input shaft with pilot bearing
  151. antifreeze pouring out of reservoir
  152. Shop says need injectors
  153. Truck won't start?
  154. 06 dodge fuel rail problem
  155. 2001 dodge 5.9 tranny fluid everywhere
  156. 12v no start
  157. no fuel from injector pump
  158. 6.5 TURBO WILL NOT START HELP
  159. 03 cummins running rough.
  160. 93 7.3 changed fuel filter still wont crank
  161. 2000 Dodge Cummins Fuel Guage
  162. white smoke?
  163. wiring
  164. 2002 7.3l wont start NEED HELP!!!
  165. Need your expertise! 5.9 Cummins won't start
  166. 03 Duramax. Lost prime? bad IP? won't run
  167. 7.3 with a little white smoke at idle
  168. 04 ford 6 liter trouble
  169. 7.3 idi wont crank please help
  170. ticking noise after injector install
  171. 2007 Cummins Problem - Help
  172. Removing front brake calipers: PITA
  173. Changed Oil Wont Crank
  174. 2004 Ford F350 PowerStroke changed oil and fuel filters and wont cold start
  175. maybe turbo? maybe wastegate
  176. 94 # 6 not firing
  177. Case 580d fuel leaking from exhaust
  178. 03 Cummins - cold start problem- gone worse ..update
  179. 95 12v starting issues
  180. no start dewy morning, eaasy start warm afternoon
  181. Tachometer that stops and starts
  182. codes..truck is sick help
  183. 7.3 Won't start...
  184. WTFreak!
  185. Need Help my truck is crippled!!!
  186. Ecm codes and heavy surging
  187. i need help bad
  188. 99 dodge cummins
  189. Code P0341-sensor not in block--01 cummins
  190. Stranded in NV
  191. 99 ford f250 cranks hard
  192. 03 dodge tranny issues
  193. 2003 48RE slip in between 1-2 upshift
  194. '05 Dodge in Jackson MS, P0111, runs rough
  195. WON'T START
  196. abs brake light with soft pedal
  197. 2000 Dodge won't start
  198. tv cable
  199. trucks stalls while driving
  200. Need help with brakes
  201. HELP 99 Ram Stuck on the side of the freeway.
  202. 1997 12 valve cummins electrical issues
  203. IDIOT NEEDS HELP...READ ON>>>
  204. white smoke at high RPMs
  205. Won't start after deleting EGR
  206. *HELP* 6.0 will turnover, no start
  207. Starter Sticking!
  208. newby needs help
  209. Ram/Cummins intermitant starting problem
  210. 95 6.5 TD about to give heart attack
  211. LB7 Duramax CP3 Mod
  212. Sudden Oil Leak
  213. need help
  214. Once again problems with new motor!!!
  215. 92 dodge D350 schematic
  216. HARD STARTING
  217. HELP Please! 12V won't start
  218. Clutch
  219. 475 isx problem
  220. lost 4th gear
  221. 6.2 injection pump
  222. 03 5.9 code poo88
  223. 03 5.9 injector install
  224. 03 cummins sounds like b series,power of a pinto
  225. I hate wires... help, please.
  226. 6.7 smoking
  227. 2003 F350 7.3 stalls
  228. 2003 CR - Having Starting Issues
  229. Tow mirrors.. electrical problem
  230. 7.3 Powerstroke wont start after sitting 12hrs or more, any help for me?
  231. '07 Chevy Classic Duramax, Limp home mode?
  232. Leaf spring or shock problems...
  233. airdog install now fuel gauge isnt readiing right
  234. bully dog help!
  235. 95' 12 valve cummins
  236. Oil Pressure
  237. 6.5 turbo diesel transfer case
  238. 1993 Silverado 6.5 turbo starting issues
  239. wierd problem with a D-Max
  240. smoke effect
  241. Truck Died--No fuel to injectors
  242. 6.0 exhaust leak at Y pipe going to turbo
  243. 99 cummins overspeed
  244. AC only on drivers side???
  245. 03 Dodge CR
  246. Loud Whistling Noise
  247. Shift points
  248. Desperate in need, 02 Dodge 5.9, 6 spd.
  249. List of codes after EGR blocker
  250. 01 cummins cam sensor
