View Full Version : Diesel In Distress - Support Ticket
Pages : 1 2 3 [4] 5 6 7 8 9
  1. HELP I FORGOT THE SPECS
  2. 7.3 powerstroke no power
  3. tranny/transfer case issue
  4. Catalytic Converter theft...now what
  5. 04 6.0 no start
  6. 03 "Popped" when getting on hiway
  7. Power steering problem on 01 Dodge
  8. 6.5 Dying
  9. 04.5 cummins start problems
  10. 04 F250 wont stay running
  11. duramax wont go into reverse
  12. opinions please
  13. possible electrical, possible vp44
  14. 03 and 05 6.0 running p[roblems
  15. Wont start 1994 7.3L IDI turbo F350 Ford
  16. Powerstroke 6.0 turbo making a hissing sound
  17. Intermittent engine stalling
  18. 2006 f250 6.0l code u1900
  19. fried PCM on 01 7.3??
  20. 05 silverado 2500hd brake probs
  21. 2006 F250 4X4
  22. 96 12v doesn't run right
  23. 97 powerstroke need serious help
  24. hard starting 03 duramax
  25. clean engine but wont run
  26. clean engine but wont run
  27. bad injectors?? lift pump?? WTF
  28. help
  29. non diesel ? overheating caddy
  30. 01 cummins fuel pressure issues..
  31. no power amd lots of smoke
  32. Help!!!! Oil on radiator cap
  33. 1997 f350 turbo diesel turns over but won't start
  34. Air Dog
  35. Cold weather starting problem
  36. 2000 ford 7.3 tow truck
  37. Airdog II fuel system troubles
  38. 03 6.0 erratic rpm
  39. 03 Cummins needs tranny
  40. engine trouble! help!
  41. truck wont start
  42. 01 ford 7.3
  43. 02 sierra abs question
  44. Dodge 48RE trans trouble
  45. Key Won't Turn
  46. 04 gmc 2500 hd lb7duramax injector nozzels to fix the fuel in the oil problem
  47. possible turbo problems
  48. electrical problem...HELP!
  49. bosh vp44 edc repair help needed
  50. 01 cummins running rough(head gasket?)
  51. 01 duramax possible misfire
  52. 05 24v cummings dodge 3500 have to spray either to get it to start
  53. No oil pressure fresh rebuild
  54. 01 Dodge Possible Gelling Issue? Lost Prime
  55. dont know how to work 03 edge EZ
  56. Ether Baby
  57. 1994 Dodge Cummins stuck in 4th gear? Help!
  58. Hard start and rough idle!!!
  59. 02 cummins won't start
  60. battery voltage/alternator issue
  61. 02 sierra weird noises
  62. 2008 Dodge 3500
  63. complete turbo shaft separation
  64. 2001 F250 7.3L power loss
  65. transmission going out?
  66. 98 camshaft seal replacement
  67. 2003 6.0 PSD stalls at 1500 rpm
  68. coolant and oil trading places 97 5.9 cummings
  69. N-14 Problems
  70. 06 dodge cummins overheats at idle
  71. 96 cummins 12v blown head gasket...
  72. Water pump??
  73. dodge axle noise
  74. 6.5 smokes under load
  75. 04.5 cr cummins dead pedal
  76. 94 F350 PowerStroke Rear brakes locking up
  77. 02 Dodge 24 valve surges with no throttle response
  78. No start
  79. 2000 Cummins, slow starts
  80. Please help! 2003 Dodge w/ electical issues
  81. 87 6.9 trans
  82. PO236-97 chevy 3500hd
  83. 2003 dodge doesn't like running
  84. 2000 DODGE 2500 NO START
  85. My brother rolled his powerstroke
  86. trouble code
  87. Tranny stopped working
  88. transfer case problems...
  89. Block Heater 1994 Powerstroke
  90. Starter whirring - won't start
  91. 4k gvsk into a 3k gvsk
  92. 2000 dodge diesel short?
  93. cruise control
  94. 04 Duramax LLY p0700 Trouble code
  95. transfer case problems help
  96. lift pump problems
  97. 2005 Duramax Head Gasket
  98. 02 duramax won't start...
  99. 1982 6.2 dura air in fuel lines
  100. 2002 F250 4R100 transmission problems
  101. 2002 dodge 2500 won't start
  102. 1998 Ram 3500 24valve Tps help
  103. Need Urgent Wiring/Light/Switch Help (1994 Ram 3500)
  104. Dead glow plug relay
  105. Bucks and sputters get service engine light
  106. 94 trans issues
  107. no low rpm
  108. NEED HELP
  109. 06 3500 megacab trans problem?
  110. Won't Start
  111. oil leak
  112. p1689 and p0232 (99 dodge cummins turbo) please help
  113. Limp mode
  114. Truck died while driving
  115. 94 12v not starting
  116. power draw on the batteries
  117. 2005 3500 low on power
  118. Air Dog out????
  119. Don't laugh...can't get truck to shut off
  120. oil from turbo?
  121. 03 jeep liberty 2.5 crd fault
  122. 96 Cummins hard starting
  123. LB7 problem with exhaust smell
  124. 91.5 cummins
  125. '84 Detroit Diesel 8.2T Starting problem
  126. Leaking fuel from canister!
  127. 98 dodge won't start
  128. truck won't start
  129. 95 ctd will not lock up or go into uverdrive
  130. Ford 6.0L Radiator is full of Oil...Please Help
  131. Hpop
  132. 01 cummins won't start
  133. 911: 02 duramax wont start
  134. won't start-blows 30amp fuse @ "wait to start"
  135. Engine Needed... Looking for Help In or Close to Tulsa OK
  136. New to site. New diesel owner. HELP!!
  137. cummins surging at idyl..
  138. HELP! Glow plug relay
  139. Duramax 65mph limp mode???
  140. 6bt squeak? (not the belt)
  141. 2002 6.6L Duramax.
  142. none of my gears work
  143. glow plug relay problems.
  144. loud knock at idle
  145. 1998 12 valve, brakes, 4x4, air
  146. no rear brake lights
  147. First time Diesel owner , ignorance is expensive
  148. 1998.5 Cummins 24v problems HELP
  149. 6.o no power
  150. L 10 has me stumped..
  151. what the heck?!!
  152. 03 Duramax glow plug issues
  153. 2004 F-350 6.0L Troubles
  154. 2004.5 Dodge fuel issue P0148 code
  155. 2004 Cummins Changed Batteries-Truck Doesn't Run!
  156. 6.4L injector o-rings
  157. Looking for a broken ECU or ECM from a Cummins QSB engine.
  158. check engine light is on
  159. 48re issues
  160. Cummins pyro running hot ...
  161. SWAPPED!! But Have A Fuel Issue?!!
  162. URgent, 47re rebuilt no gears
  163. 99 7.3 Chugging
  164. 2008 F250 Check Engine Light..
  165. wont start
  166. hard starting
  167. running on 3
  168. Bleeding system without bleed screws
  169. dead
  170. Rough Idle at Stop Lights
  171. Won't Start
  172. 01 dodge cummins hard start good fuel psi
  173. Need help with 88 Ford 7.3 diagnosis
  174. hard start ctd
  175. 1996 dodge 3500 frame problems
  176. 1997 Powerstroke won't start
  177. Air dog ?
  178. Clutch!!!!
  179. lock up prob
  180. throttle position sensor out ??
  181. 98 dodge 12 valve sudden no start
  182. 99 7.3l turbo won't start. Wts light not on.
  183. c4500 wont go over 40mph, speedo reading 85
  184. Large oil puddle under 1999 powerstroke
  185. The Epic Head Scratcher
  186. 911 truck wont move 911
  187. No power when cold
  188. 2008 f250 Spitting coolant need help
  189. South Bend 13125-OFEK - slippage ?
  190. need some help block just to cold
  191. 911 INJECTOR HELP
  192. Sct livewire dpf delete HIGH IDLE and need clarification pls help!
  193. 1993 Chevy 6.5 TD
  194. 1994 6.5
  195. 1985 ford 6.9L turbo
  196. hard start/no start 02 7.3
  197. Riding Rough
  198. gen light on low charge
  199. blowing white smoke
  200. New lift pump in 12v leaking
  201. lost prime wont start
  202. Cold Start and Rough running
  203. 03 Duramax White Smoke at Idle
  204. trany temp lighgt wont go off
  205. Oil pump replacement
  206. COLD START PROBLEM
  207. 06 5.9 tranny problem
  208. p 0973....
  209. 93 cummins new IP and now cant find tdc
  210. irratic altanator/ charging
  211. p0700 code
  212. Need help.. tranny issues
  213. No first gear?
  214. Truck Wont Start!! HELP!!
  215. 92 f250 7.3 non turbo cuts off when tap throtle starts fine
  216. HELP! power steering and brakes gone!
  217. fuel leak
  218. Cold start issue still after plugs, controller and HPOP resevoir change
  219. coolant coming out exhaust
  220. UH OH! Fuel pressure issues WITH FASS
  221. 99 24 valve-crank no start, unless use either
  222. 91.5 5.9 cummins wont start
  223. 99 24 valve-crank no start, unless use either
  224. 2000 dodge diesel dead
  225. Excursion 7.3 broke down in Murfreesboro TN
  226. burning more then diesel
  227. 95 dodge violent shaking
  228. no hot air from heater
  229. Help with 2003 injector change
  230. 48re tranny rolling in Park! Please Help ME!!!
  231. code p2262
  232. 5.9 cummins running trouble
  233. front main seal
  234. Speedometer misreading on 91 Dodge
  235. drum brakes on a 96 2500
  236. no peddle resopnse
  237. Houston People
  238. F250 6.0L: 2 turbo's in 4mo. engine trashed,dealer says we starved of oil, no warrant
  239. 91 Cummins-cut out while driving and wont start
  240. HIGH IDLE -SCT Livewire 6.4L DPF/CAT Delete installed today - HIGH IDLE
  241. 08 6.4L EXHAUST SENSORS (DPF/CAT DELETE PIPE)
  242. 1997 Powerstroke Shut-off No restart
  243. 99 dodge transmission issues
  244. Transmission radiator LEAK!!
  245. 2000 cummins, rattle
  246. 94 cummins no speedo tach or alternator
  247. 95 7.3 won't start in 40 degree weather - low oil presure
  248. i need some help with my 6.2l
  249. Help! 2005 cummins PO192 code no run
  250. need help pls. possible ecm?
