View Full Version : Diesel In Distress - Support Ticket
Pages : 1 [2] 3 4 5 6 7 8 9 10
  1. seeping Trans fluid
  2. Reman or Repair? 7.3L with Gas in Engine
  3. 1984 6.9l fuel problems
  4. 2000 F250 - Vacuum cleaner sound ?
  5. 2007 F350 6.0 diesel-white smoke
  6. 48re trashed! help
  7. help!!! turbo prob
  8. 2003 3500 4x4 Died on the road, Hasn't started since.
  9. need help
  10. Transfer Case
  11. 04 6.0L excursion, engine cuts out
  12. 95 GMC 6.5 Turbo Diesel stalls
  13. Truck shaking from stop need help!
  14. Pulley squeaking and its driving me crazy!
  15. 03 cummings start problem
  16. Help I believe there's a short! 04 F-250
  17. 03 7.3 runs rough
  18. 1993 7.3 IDI won't start
  19. 1993 ford f250 diesel
  20. 03 Dodge Brake light issue
  21. Will not go past 2200rpm, popping and white smoke..
  22. FLUID COMING OUT CRANKCASE OIL VENT TUBE DURAMAX LB7
  23. How to break a Cummins 6BTA Lift Pump?
  24. 2006 wont shift to 2nd
  25. 97 f-350 with right bank of cylinders down
  26. no acceleration, sputters
  27. LB7 DURAMAX WONT START NEED HELP
  28. 6.2 wont start
  29. 03 F350 6.0 Help - not starting
  30. 7.3 crank no start
  31. Roscod
  32. low hpop pressure
  33. Lose of MPGs
  34. New to Diesel trucks, hard to start.
  35. Is this bad?
  36. Transmission Problems with a 4WD 7.3 Automatic
  37. 5.9 idle keeps climbing at idle
  38. golf mk2 gtd problem
  39. 96 PSD RUNS ROUGH. NEED HELP!
  40. 99 cummins problem
  41. 1989 f250 losing prime while running
  42. Jetted jetta
  43. FUEL PUMP REMOVAL
  44. engine running away
  45. Need help fast -- brake problems!
  46. electrical?
  47. 2005 6.0 Rev sounds
  48. 08 6.4 will idle,but wont run. LOOKING FOR HELP ASAP
  49. 92 6.5 3500hd severe problems
  50. 08 6.7 Cummins Pulling 18,000 Brakes Aint workin
  51. 04 Chevy Kodiak Duramax c4500 dies while driving
  52. help with an injection system
  53. 95 Suburban no high
  54. Edge comp install.
  55. oil pressure sending unit location
  56. upper rad hose stay hard even after sitting overnight
  57. any help here?
  58. Low Boost pressure, high exhaust temp, poor fuel mileage?
  59. 01 24v throwing codes
  60. Ford BJ Dana 60 help!
  61. stalling
  62. Cummins 5.9 liter 6BTA Marine problems
  63. Excessive Smokes and Exhaust popping.
  64. Any good diesel mechanics in CT?
  65. Very loud engine knock!!!
  66. smarty ssr defuel
  67. 96 dodge ram transfer case problems
  68. oil filter housing
  69. vp died....can i go ho pump to so
  70. Help, towing issues
  71. Torque Converter Lock Up Not Working
  72. Pillar guages wont work!
  73. Fordson Dexta Ran Away, Now What?
  74. HHelp-blowing blueish smoke-no power,5.9,01'
  75. 02 cummins wont start
  76. DPF Problems
  77. Can't get the starter to engage!
  78. Water in Diesel
  79. 4r100 slippage.
  80. Help!!!!!
  81. Need help fast!! Stranded at Walmart in fire lane...
  82. Gauge Cluster Problems
  83. Cold start advance
  84. 01 cummins small miss
  85. Programming issues
  86. 6.9 p1689
  87. Emergency camber ?
  88. 6.9 liter burning oil
  89. deisel in oil help
  90. 99 7.3 Powerstroke Strange Issue, Please Help
  91. P0098 Code and oil pressure loss at idle
  92. Rattle/ Grinding noise at idle and low RPM
  93. Codes Rough Idle No Power Cyl's 4-6 and
  94. AC quit working
  95. injection pump
  96. 05 6.6 fuel in oil
  97. 2008 will not shift past 4th after screwing up update on mini max
  98. Help!!
  99. 01 cummins loping and jerking..
  100. stc replacement problem
  101. Need help near Kearney/Lexington
  102. 99 cummins fuel tank module leak
  103. 86 Chevy p30 6.2...
  104. turbo failure
  105. 97 psd lots of codes
  106. I need an engine serial number
  107. dump bed kit removal
  108. Need advice-DPF
  109. idle high
  110. what causes turbos to have oil all over the place
  111. 97 ram 3500 parking brake tensioner?
  112. 2000 6.5 turbo runs some and then won't start
  113. egt's went up after installing bd twin turbo's
  114. 94' f250w/ 7.3 idi n/a tps screws
  115. 6.9 hard starts and white smoke
  116. 98 6.5l runs then stalls
  117. 06 CTD Suddenly died while driving, now won't start
  118. just installed airdog 150 and truck has no power
  119. dodge power steering w/ 6815
  120. 83 6.2l stopped running
  121. 97 ford f350 crank but no start.
  122. 1993 k3500 6.5 td cranks but won't start
  123. 04 dodge 3500 wont start unless its plugged in
  124. 2004 E350 6.0 NO ICP PRESSURE
  125. 2004 Dodge 3500 tranny problems?
  126. Random black smoke
  127. code p0234 and p1690
  128. 98 dodge ram 24v loss of power
  129. No Reverse
  130. rpm,s jumping up and down
  131. At a loss... Losing fuel
  132. ford 6.0 help lots of smoke
  133. 6.5 shuts down, time to upgrade parts?
  134. 97 5.9
  135. 2008 dodge 2500 shifting problem
  136. cummins fuuel priming. isues
  137. ford 6.0 problems
  138. help
  139. Injector stuck!!
  140. 07 6.0 235k miles repairs gone wrong
  141. Fuse blow on AIRDOG 150
  142. 98.5 24v 4x4 brake issue
  143. 1995 to 2000 motorswap-loss of power
  144. Hot to bleed clutch slave cylinder? '88 7.3
  145. 06 Dodge 3500 5.9 Trans. (auto) wont drop into gear...
  146. F250 with a no start
  147. Fuel Problems on Mazda B2500
  148. The Dirty LB7 strikes again
  149. noisey motor
  150. PMD Bad???
  151. New to cummins fuel problem
  152. Fuel Problems
  153. transmission help
  154. Transmission help, please..?
  155. Anyone have any idea what this is for?
  156. 1994 cummins dies....
  157. 96 12v cummins
  158. 2006 F350 6.0
  159. Snapped a bolt on exhaust manifold
  160. hard starting
  161. 94 6.5L Slow crank
  162. Replaced O rings...now won't start!
  163. 95 chevy
  164. ECM/PCM Rebuilt
  165. code 336
  166. Cummins ISM Camshaft removal/installation
  167. 95 Dodge Downshifting
  168. 1999 F350 Computer ?
  169. Map sensor voltage low
  170. Need Help!!! A.S.A.P.
  171. 4 wheel srice problem
  172. 2007 Dodge Ram 2500 P0868 trouble code
  173. 2003 Duramax fuel problems
  174. White smoke and missing
  175. Dropped something in tranny!
  176. 2003 dodge cummings looses power
  177. 47RE Problems
  178. 2006 mega cab 4x4
  179. 2006 mega cab 4x4
  180. '01 F250 4x4 problems
  181. 1999 7.3 not getting fuel
  182. 1994 6.5l pouring oil!!!
  183. 47rh not down shifting
  184. 1997 Dodge Ram 2500 5.9 turbo diesel has power lost
  185. 911 Help 95 powerstroke wont stay running
  186. 04-dodge 3500
  187. Any suggestions much appreciated
  188. '03 Cummins 5.9 will NOT START when HOT
  189. 01 lb7 wont start
  190. 1989 GMC 6.2 Service Fuel Filter Light
  191. help 6.5 wont run
  192. truck won't start
  193. Questions on a 99 Dodge 24 valve
  194. 5R110 tranny with water in trans fluid-'08 f350
  195. cummins won't shift won't charge and tach don't work.
  196. 7.3 no start
  197. Trans Slipping During Second Gear Shift
  198. fuel problem maybe?
  199. cummins white smoke and miss
  200. 2003 6.0 Super Duty shutting down when brake applied or warm
  201. No fuel, 7.3 idi
  202. 05 DT466 HPOP?
  203. tranny wont go into gear
  204. what to buy
  205. quick Help SPLINE NV5600
  206. 99 cummins with delayed wait to start light
  207. leaking steering fluid? and making whining noise help
  208. 5.9 clutch
  209. 12 valve running rough
  210. mercedes intermittent dash light problem
  211. 96 oil leak.
  212. Steering Wheel/ Key both LOCKED
  213. NEED HELP!!
  214. HELP
  215. 07 5.9 Cummins stalling/long crank
  216. Clutch / transmission issues.
  217. Oil leak
  218. vaccum pump
  219. 95 dodge 12v white smoke breaks up
  220. fuel pressure needle valve set-up
  221. replaced my vp44 and now it threw a p1688 code, Truck died on me!!!
  222. 01 cummins shorted vp44 wires
  223. 6.2 No Fuel At Injectors
  224. 05 Duramax LLY Tuner?
  225. a case of the shimmy's
  226. fuel filter lossens
  227. Oil leaking into coolant??
  228. ctd oil leak
  229. 1991 cummins question?
  230. Clicking under hood 1986 6.9 won't start
  231. Help w/2003 Dodge 2500
  232. Fuel delivery issues
  233. Stuck Again !
  234. erratic shifting
  235. 24v pcm and ecm not connecting with scan tool
  236. 04/gmc c6500 w/duramax oil in cooling system
  237. Help. Windows won't roll up
  238. 2001 cummins high idle miss
  239. 1984 F250 6.9 just replaced vacuum pump now won't start--clicks!
  240. 99 powerstroke sounds like miss
  241. 04 cummins will not start (help)
  242. PLEASE help!! hard to start, and extremely sluggish behavior
  243. Fuel in Coolant, Injector questions
  244. Code P2284???
  245. P 1690 code missing and white smoke!!!!
  246. 1993 cummins temp problem
  247. Push rod trouble
  248. gas in my diesel
  249. need help
  250. 05 Liberty TRD that bucks at 2500 RPM
