- Diesel leaking between engine and tranny, 96 GMC 3500 turbo
- I got an oil leak
- Anyone Near Albany NY Help Needed ASAP
- 2003 6.0 stall after about 3 miles - HELP
- fuel running back to tank
- 1999 ford f350 7.3 powerstroke won't crank the engine, HELP!!
- 2005 Ram 2500 HELP!!! lots of smoke and nasty KNOCK!
- 6.5 turbo no overdrive 4L80
- possible fuel pump
- low oil pressure-missing
- HELP!! truck keeps losing prime. 1998.5 24v
- Air in fuel system
- fueling problem HELP!!!!
- 03 ram 3/4 ton front inner axle u-joint
- start then stalls
- 94 cummins ac problems
- HELP!! Friends truck is vomiting
- no rev/upshift, low and second ok...??
- 95 6.5 TURBO DIESEL WONT START
- Oil from down under........
- F650 6.7L Cummins DPF
- help 2004 dodge 2500 cumming turns off
- Diesel down in Cody, Wyoming
- brakes...
- Diesel starting problem
- dodge disel code -p-1688
- 6.5 clutch
- Engine Won`t Shut Off !!
- Entire Steering system, junk in 2 days..
- rear brakes
- Need help with trans overdrive solenoid
- 06 Ford lack of power hard start
- bosch ve pump rebuilding
- truck dies. no codes. no check engine light. restarts after 30 minutes
- Turn key, and nothing happens
- HELP P-pump shaft thread size?
- P0192 code, wont start
- I LOVE MY TRK BUT IT WONT START FOR ME ANYMORE. DOES IT HATE ME?
- 1997 powerstroke problem from superchip
- Truck Running Way To Hot
- Help!!
- 97 Dodge Cummins hissing sound?
- 1998 jetta tdi
- CAT 3126 NO POWER PLEASE help!!
- hard start when hot. again....
- New member with a problem 99 7.3L
- need help with pump in tank conversion on 99
- 99dodge automatic blues
- Just threw a code running rough?
- 6.7 exhaust brake
- PCM
- 06 dodge looses power when you get on it.
- Huge Oil Leak 7.3 Diesel 2000 F350 - Out of Ideas Need Help!!!
- 2001 dodge diesel
- no power
- 06 Ford codes Lack of power
- not charging right
- 95 Psd Clutch problems HELP!
- Fuel Guage Sender
- KW w900 Cummins BC 400 black smoking no power HELP!!
- bad blow by
- HELP!!! P0237 on my 2001 Dodge
- trans leaking
- Apps / VP44 bad, Both?
- Hard starting in a 2004.5
- 06 dodge starts then dies
- Idaho Falls
- leaking from the water in fuel sensor / check valve
- 6.5 injection pump
- Need help moving to Texas..Limp mode C0910
- Before/After Posting.....Please Read
- 94 Chevy 6.5 turbo issues
- major exhaust leak
- got the cummins running but has an issue
- locked out
- 03 Cummins No start
- Squealing Powerstroke Turbo
- Cummins hard starting
- wont start after changin the fuel filter. HELP
- Cummins hopping!!! need help!!
- Dead batteries
- Crap in the fuel?!
- 03 2500 Ram wont start
- 6.5L Turbo Troubles???
- Hard Starting
- Duramax losing prime
- 04.5 cummins fuel gremlin
- I need a 1999 Cummins Fuel Canister Cap!!!
- Transfer Case all brokey
- OIL LEAKING BAD
- 2003 f250 problems with multiple codes
- Duramax wont start
- Duramax RPM Limited
- Power loss
- 98 Cummins Smoking white
- NTC 444 Water in oil
- Having Problem with Rear Brakes
- 1993 Chevy 6.5 turbo stalling problem
- 91 12valve tranny problems
- Auto trans starts in second gear after stop
- Torque converter won't unlock at times
- '00 Cummins CKP Issue
- alarm;truck wont start
- 6.0 spins but no start after driving
- wheels lock when downshifting to 1st
- 03 F-350 6.0 Trans temp guage acting strange.
- 04 Cummins 600 - Dealer Can't Reprogram ECM
- 04 6.0 Won't Crank
- 01 dodge clutch bleeding help
- timing case and ticking noise
- Limped home
- 96 powertroke start prob
- 96 powerstroke prob
- Ford OBD II Trouble Codes
- Generic OBD II Trouble Codes
- Help with P2509 Code
- The motor broke
- Help P0148 and P0483
- Brake lights stay on wont go off
- ticking?
- duramax (LB7) out of warranty
- damned ol' 6.5
- Distressed and stressed
- Glow Plug Or Relay Problem
- 1999 7.3 Won't Start
- Daytime Running Light Help!
- 91 dodge fuel injection pump instalation
- Tranny problem
- White smoke after changing fuel filter housing
- 7.3 Will not start
- dodge lift
- Junk Coaltrain Trans Need help!!!
- charging
- 7.3 l loud popping noise
- Stalling ,Hard start P1650 / J1850 Codes...2003 Ram Cummins 6spd
- 01 Dodge Ram 2500 Voltage Guage
- no brakes on slowtowpig
- ABS problems need help ASAP
- 12V Fuel Problem
- 99 f-350 or 450 shuttle bus help
- Front Wheel Bearing Change
- 894 code 4L80E
- fuel trail
- 2000 5.9 24V - Wont Start
- Oil Leak
- 12V's Dead... No coolant flow, oil leak, #5 cylinder not firing!
- runs out off oil for high pressure pump
- 2000 7.3 Cold Start Problems
- Clutch or Slave Cylinder 05 TDI Jetta?
- no start on dmax this morning
- 93 F-350 still won't run
- 1999 ford f350 wont start
- Shot in the dark: Cant get passenger side low beem to work
- Broke Down in Indiana
- it wont start
- This Truck Is Gonna Drive Me To Drink!!!
- 82 6.2 died and no start.
- 93 F350 7.3 quits running
- 03 Dead AGAIN!
- loud engine noise
- she wont start!
- TRANS PROBLEMS
- 6.4 powerstroke lost stock ecu&tcm with sctlivewire extreme what do i do
- 97 cummins waterpump explosion!
- my 12V cummins died today...need some ideas guys!! and HELP
- 08 Dies While Driving Down the Road
- ***08 DURAMAX WATER IN FUEL*** NEED HELP!!!!!
- Truck question??
- Code 380
- Edge Attitude Madness
- 2001 Dodge Ram 2500 Starting Issue
- what am I missing
- 48re
- Trouble shooting a ford 7.3
- Ford E40D trans, that says it all...
- 03 Cummins DOA
- Waiting to start forever
- 2007 Mega 5.9 cylinder misfire
- Dodge transmission issue
- Jetta beater help needed ASAP!
- It Happened...P0628
- different problem
- trans help
- 99 F450 dies going down the road, GEM?
- Need Help
- 2000 Hard Starting/Not Starting.
- Battery harness ?
- 92 cummins low oil pressure
- 01 transmission trouble
- Fuel Leak
- Fuel leak on 99 Dodge
- 95 cummins
- Buddys truck problems
- stalled 7.3
- DEAD 5.9CR
- 99 Dodge 2500 wont shift
- 99 24v surge
- 2002 7.3l F350
- 6.0 Ford Trouble
- trucks down
- bad fuel problems
- 1st gen taking a dive
- 99 Dodge Ram 2500 4x4 ABS & Brake lights
- thermastat
- thermastat help
- Engine Rebuild help
- 99 Ford 7.3L 500K miles, Engine Shuttering and Axle Noise
- Sand in fuel
- Help solve mystery!
- Vehicle Speed Sensor question
- problems-always problems / 24V Cummins Fueling Issue
- Help runaway..... Sorta
- 2004.5 Dodge cummins dead
- abs wont work
- 97 power stroke not running
- Duramax wont run
- Need Help/Where to start
- Help On A First Gen
- Slight Surge
- Surging Around 80-100 KM's An Hour
- Help. I need Injector Line #6 for 1987 Mercedes 300 SDL
- 95 CTD Won't Stay Running
- New 47 RH No 3rd gear!!
- Missing, Low Oil Pressure Instantly!
- Track Bar Predicament
- 2003 F250 6.0 Stumbles At About 3000 RPM
- Power Steering Line Nut Size
- Help On Tranny Mount
- Timing Off
- High Mileage 2001 Cummins Cutting Out
- Truck Is Dead
- 3rd Gen 2004 Belt Diagram
- Help I Got A Powerstroke
- 2002 Golf TDI, Accelerating Issue
- 2000 Ford 450 7.3 With Multiple codes
- Tranny Problem I Believe
- Vacuum Pump Going Out?
- 97 Powerstroke With A Miss
- Check Engine Light On
- Help, Need Injector Line #3 for MB 300 SDL 1987
- Dead 7.3
- Help Air Conditioning Not Working Correctly In 99 3500
- Need A Good Mechanic
- Trans Locking & Unlocking
- Help Codes
- Check Engine Light / MAP Sensor Unplugged
- P0299 Turbocharger Underboost DTC
- Good News/Bad News
- HELP, HAVING PROBLEMS AND HAVE NOT EVEN MADE THE FIRST PAYMENT
