View Full Version : 5.9L Rotary Performance
Pages : 1 [2]
  1. A-1 stud install
  2. pump head
  3. Just got a D350 and want to find some cheap mods...
  4. injectors
  5. ksb spacer??
  6. 4" downpipe pics
  7. Anybody Do a 727 to Th400 Swap?
  8. S300 turbo good or bad??????
  9. 4" downpipe on stock turbo? 5" for the rest?
  10. head studs
  11. Factory air to water aftercooler
  12. black smoke
  13. NV4500 swap
  14. which turbos to use?
  15. compressor wheel blades
  16. Gauge mounting
  17. fuel pump and regulator
  18. twin turbo question
  19. Which seat will fit if any
  20. Lucas POD's
  21. Exhaust Housing How-To?
  22. M&H Inc. Fuel Pin vs. Denny T Fuel Pin??
  23. Tranny locker
  24. 47rh trans swap
  25. 330 MARINE INJECTORS
  26. 09 vgt tubo
  27. Exhaust Pyro Help.
  28. 93 front end lift
  29. I want a flat bed
  30. 1992 cummins 12 valve
  31. Airdog and fuel heater...
  32. PODs and the washer size
  33. Cummins 12 valve electric fan install write up
  34. 5x14s on a stock 21cm turbo??
  35. Put a hood stack on the first Gen
  36. really sluggish
  37. Just a thought
  38. what do i need
  39. what turbo???
  40. POD injectors on diesel mileage
  41. Autometer or Isspro?
  42. Pic Of The P-Pump Swap!
  43. another wastegate hx40 questions
  44. exhaust to turbo
  45. HT3B Oil drain
  46. turbo ?
  47. Smokem... Injectors...
  48. 5x.014s are in, Wow thanks SDX
  49. S300 install
  50. just a dumb question
  51. First Gen Grill
  52. Holley blue/return line?s
  53. can you cam??
  54. injectors
  55. My 1st, 1st gen injector swap?
  56. Another mod question
  57. nozzels
  58. Disc Conversion For Your Dana 70 Rear Axle
  59. 9mm to 7mm conversion
  60. fire ring
  61. BHAF part numbers
  62. hx35(w) vs hx40 vs s300
  63. Shaving The Timing Advance Piston
  64. turbo choices
  65. towing setup
  66. Want to put a '95 hx35w on my '93 Anyone tried?
  67. Opinions on my plan for a first gen build
  68. Compound Turbo set up
  69. Injector questions.
  70. truck ideling high
  71. Lucas Prince of Darkness POD injectors
  72. scheid diesel 60 hp bosch injectors?
  73. Banks??
  74. over drive in a automatic?
  75. First Gen Gov. Spring
  76. First Gen Boost
  77. run away question
  78. VE Pump tuning
  79. fuel line upgrades
  80. what hp more hp out of 89
  81. strait pipe?
  82. pods
  83. Power Upgrades for an Intercooled 1st Gen
  84. How hot is too hot?
  85. Looking For Some Extra Power
  86. 2nd gen radiator in a first gen
  87. Low Pressure Piston Lift Pump
  88. any 3 gauge pillar pods for my 93 12 valve?
  89. Boring Out A Motor
  90. BHAF and Old Smokey mount in the works
  91. Trip to Virginia and the 366 spring
  92. Need advice on hp upgrades
  93. dual 4" exhaust with 6" tips
  94. Star wheel
  95. Injectors
  96. KDP, wrong gasket
  97. 05 head gasket on a 93
  98. turnin up my 91 cummins
  99. nitrous to propane???
  100. Kickdown
  101. 14mm or 16mm turbo housing
  102. Fuel Screw Loc.
  103. Finally Found A Roll Pan
  104. hx40? to BIG?
  105. BD Super B Turbo
  106. Call Me A Bottle Baby If You Want But It's Nitrous Time
  107. 3200rpm Spring Install
  108. Turbo applications
  109. turning the pump up
  110. ASA Modified's CAI.....
  111. No faith in the VE pump
  112. C.R. turbo an upgrade for 1st gen?
  113. grinding the fuel pin
  114. Stuff Is Falling Off My truck Again, This Time it's The Turbo
  115. AirDog Dodge FP-100-150 1989-1993 Install Manual Rev. 3-3-09
  116. Tow rig bombing
  117. first gen showin up a chiped 6.0
  118. 600 hp first gen
  119. first generation slide show
  120. injectors
  121. Idle adjust
  122. what tweaks can i do
  123. transmissions Promblems
  124. Stuck fuel pin
  125. Rollpan
  126. Cobra stage 4 twin turbo
  127. fuel pin question
  128. Injectors
  129. Suggestions On Which Injectors To Buy
  130. Pullin Power
  131. 1st Gens Suspension Wise
  132. Gov Spring Numbers
  133. Trying To Figure Out The Mod Path For My Dodge
  134. VE PUMP RELIABILITY
  135. Reducing Vibrations On A 91 Cummins
  136. VE pump does not like -76 degree temps
  137. Transmission Swap Info
  138. Got The POD's in... HELL YEAH!!!
  139. Cheap Nitrous Kits - Budget Nitrous
  140. H1C/H1E Hybrid
  141. 1989 Dodge Ram - VE Pump Tweaks On The Cheap
  142. Cut Fuel Pins....
  143. 12 Valve To 24 Valve
  144. New Tiny Tach!
  145. hx-35 swap
  146. Aeroturbine
  147. SMOKE
  148. VE To A P-pump
  149. 89 12v High EGT's
  150. 12 valve questions
  151. Trans temp
  152. Turning Up A '93
